RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   What engine is this (https://www.rcuniverse.com/forum/engine-conversions-92/5173287-what-engine.html)
tyor 12-28-2006 01:20 PM
What engine is this
1 Attachment(s)
HI
Anybody know what engine this is. It´s written made in canada under the engine, and made in usa on the flywheel. The piston is 36.5mm and the stroke is 32mm, that shuld give 33ccm. I think it is taken from a chainsaw or a weed eater, The weight is 1650gram with prop adapter and engine mount.
captinjohn 12-28-2006 02:27 PM
RE: What engine is this
Not sure....it may be a Quadra engine. I think the engine was in a Pioneer Chain saw. Looks like it is all ready to go. What are you going to put it in? Capt,n
tyor 12-28-2006 02:41 PM
Thanks for the info. I have to mount a bearing inside the motor mount to take the thrust from the propeller. it is only needle bearings in the engine. I´m going to try it in a CMPro AT6 Texan. VS=209cm. I have 16x10 and 18x10 props. What should i try on this one.
Antique 12-28-2006 03:12 PM
Good old Q35 or 42...No need for a bearing inside, there's a bronze thrust washer outside both roller bearings on the crank...
Check it out at bennettbuilt.com
18-6 for the 35, 18-8 or 10 for the 42...
tyor 12-28-2006 05:40 PM
Thanks :) I was not shure the bronze washer was enough. Guess it is a Q35.
tyor 12-29-2006 08:57 AM
Started the engine today. Very easy to start and running nice, shall do some measurement of the RPM later.
Thanks again for all help :D
flyrc100 01-05-2007 02:41 PM
It will turn an 18x8 APC REAL good if the engine is in good shape. 7500 rpm or so.
tyor 01-22-2007 05:06 PM
Hi tested the engine with a menz 18x10 today(the lokal dealer didn´t have a 18x8). it have a realy low nice idle :) Shal messure the rpm one of the first days.
What percent of oil should I use. is 2% enough for this engine?
davewallace 01-22-2007 05:13 PM
Tyor,
Most people 3% or about 32 to 1. Some older Quadras didn't have a needle bearing at the top of the rod. This would require more oil, 3% to be safe.
Dave
w8ye 01-22-2007 06:40 PM
There are little cans of 2 stroke oil at the hardware and discount stores. The small ones go with one gallon of gasolene and the big ones go with two gallons.
A 4oz bottle with a gallon of gas gives you 32:1
tyor 01-23-2007 04:00 AM
We dont have gallons and oz here in norway, we use litre and dl. [8D]
32:1 shuld be 1dl oil in 3.1litre gass. That should give me 3.2litre fuel at 32:1.
davewallace 01-23-2007 02:33 PM
Tyor,
30cc for each liter would be 3%, which is approximatly 32 to 1.
Dave
tyor 02-25-2007 07:51 AM
Tested the engine today. Got 8200rpm with a menz 16x10. Should I try a bigger prop?
How heavy warbird kan I fly with this engine?
bdtsr 02-26-2007 07:11 PM
Looking at your one picture, I see a black wire coming from under the flywheel. This is a points type ignition on your motor. Pop the muffler off and see how many rings are on the piston. 1 ring is a 35cc. 2 rings is a 40cc. They look the same. Yours has an aluminum prop hub which would not be on an earlier engine as they were steel. Could have been changed though. Bennettbuilt.com has an exploded parts diagram for these engines. I have both the 35 and 40cc engines. Good runeers just a little heavy.
tyor 02-27-2007 01:38 AM
Hi
have taken off the muffler and it has 1ring. Have also messured the piston and it is for sure a 35. I am going tu try a 18x8 prop and se what RPM I get with that.
