Cheap'n'quick models for converted engines
Dear All
I have been using the search engine on RCU but have found very little info about large models built out of cheap foam materials. I dare not ask about this in the Giant Models forum because it seems full of threads about 30% all moulded, expensive aircraft. I like models that don't cost a second mortgage. It makes me more relaxed when flying them, knowing that if I crash it won't have cost me a lot of time and money. I mainly build micro R/C planes under 1oz AUW - often from various foams. Used right foam structures can be very light and strong. I don't see why a decent large model couldn't be built from 6mm Depron with a bit of hard balsa or spruce in strategic places. Ordinary beaded styro can also be strong when covered with brown paper. The only large model I know of that uses Depron is this one: http://www.flyelectric.ukgateway.net/flybaby.htm Has anyone here built models for converted gas engines from Depron or Styro? Michael |
RE: Cheap'n'quick models for converted engines
I've used foamboard which is a foam and poster board sandwich, it works great and it comes in 40x30 inch sheets, what i do i cut the fuse sides and reinforce them from the firewall up to the seat of the wing with 1/8 lite ply for the big birds and 1/16 balsa for the regular planes.
I will try to take some snap shots and post them. |
Epilot you need to be looking at the spad forums on here or go to http://spadworld.net/forum/ and check the gasser section. there is a few made of foam board /coroplast .
Check it out. lots of reading. |
www.crazyherb.com
large floaters and delta.i built one that looked like a sig spacewalker.80 inch ws,flew it with a poulan 25cc featherlite.even with a low powered engine it still flew great.no plans,TLAR dimensions. |
| All times are GMT -8. The time now is 07:22 AM. |
