Shindaiwa 80
Anybody wondering about a Shindaiwa 80 4 stroke ? You saw it here first..;)
Have one here, staying up till the wee small hours converting it... Looks good, will weight about 8 1/2 lbs, no way to make it any lighter... Might even get someone to call it a "masterpiece" like the Stihl 64.9 in the gasser thread ;) Funny, no one ever called one of my 4 Stihl 64.9s a masterpiece... |
RE: Shindaiwa 80
Get some pictures on here Ralph!!! Who cares if it's not quite done...we like seeing progress pics!
RE: Shindaiwa 80
RCIGN1 How is the Shindawa 80 4 cycle coming? I bet it sounds neat! Capt,n
RE: Shindaiwa 80
Ralph!!!! Photos please!~). That is quite heavy.
joe |
RE: Shindaiwa 80
It's close, needs the 2 piece hub drilled and the sensor mounted...will run tonight....:D
Ran it at 12:05 AM...Easiest starting gasser ever...24-10 PK prop, didn't tach it...stock muffler is so quiet you can hear the prop...Used two different carbs, the stock small one and a WYK33 with an adjustable high speed needle...Both work fine, the 33 seems to have more rpm, will tach it tomorrow in the daylight... The C&H syncro spark needs to be flipped once to set the retard..It starts so easy that once on the first flip, with the ignition set at 28 BTDC, it kicked back..Subsequent starts will be with a serious first flip, just in case... Minimal vibration, no worse than any other big gasser, better than some... Didn't weigh it, still on the test stand.... Gonna be a great engine, maybe even a "masterpiece" like Brillelli's Stihl 64.9...;) |
RE: Shindaiwa 80
Boy I can hardly wait to get this engine coupled up with that big 4-blade prop. I'm just about finished with the reduction unit/variable pitch mechanism so your timing is perfect!
Thanks Ralph! |
RE: Shindaiwa 80
Great news Ralph! You are a luck man Tom! Lets see some photos of that reduction drive! RPMs when you get to it please Ralph, and by the way YOU ARE a Masterpiece Ralph!!!! :D
joe |
RE: Shindaiwa 80
Can't call it a masterpiece without a bunch of photos to admire. Video with sound would be almost too much! You must be use to hearing the comment, You are a work of art! :)
RE: Shindaiwa 80
come on ralph, you're killing us here....we're begging for some pics!
RE: Shindaiwa 80
Later today, I'm trying different setting on the timing....And maybe a different carb..The stock carb is one of those rotary barrel things with a very stiff return spring and no high speed needle adjustment...Hard to do everything, there are people waiting patiently for their conversions and repairs...The shindaiwa get worked on late at night, my wife gives me a midnight curfew ;)
RE: Shindaiwa 80
Ralph, is this Shindaiwa 80 conversion one that you plan on offerring as a commercial service or a personal project? This might be a good match for a 1/3 scale Pup I'm building.
RE: Shindaiwa 80
1 Attachment(s)
OK, here's a couple of photos of the beast.
Excellent work by Ralph, I can hardly wait to get this on the test stand and coupled up to the variable pitch prop system. I know it's off topic, but attached are a couple of snaps of that as well. Gotta run, will update with performance data when I get it! |
RE: Shindaiwa 80
Ok, Since no one has said it already, that conversion is a Masterpiece!
Hehehehe....:) |
RE: Shindaiwa 80
Very easy conversion, the mounting plate bolts on where the pull starter was, the crank taper is the same as a G62, the G62 carb works fine...The casting was left on the front in case a mount was needed for the variable pitch prop mechanism...Ignition is C&H syncro spark, the sensor is in a ring pressed on the front of the case...
RE: Shindaiwa 80
What ever happened with this conversion? Has it ever been installed and flown in a model? What size propeller can it swing? at what rpm? Seems that the whole thread died quietly, can someone shed some light on this conversion please?
Joshua |
RE: Shindaiwa 80
Come on guys, somebody must know something about this engine?
RE: Shindaiwa 80
ORIGINAL: N99JH Come on guys, somebody must know something about this engine? http://www.rcignitions.com/index.php |
RE: Shindaiwa 80
Thanks for the advice, I tried it but could not find anything.
Joshua |
RE: Shindaiwa 80
Try posting the question in the general forum.
Ralph C. Will get back to you. |
RE: Shindaiwa 80
[sm=bananahead.gif][sm=drowning.gif]
| All times are GMT -8. The time now is 05:04 AM. |
