RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Poulan 331 Pro (https://www.rcuniverse.com/forum/engine-conversions-92/5310091-poulan-331-pro.html)
jrjr2u 01-23-2007 09:36 AM
Poulan 331 Pro
1 Attachment(s)
That is what it says on the shroud.... and thats all it says. I don't seem to find this model listed anywhere to get specs.
Plastic shroud is yellow and it says - Poulan 331 Pro
Anyone know the size? I bet its 31cc
In the pic there is a homelite 25cc on the left for comparison.
Also, it came with good spark, good compression but no carb. What was the stock carb and since I need to get one, what venturi size works the best?
Thanks!!
jrjr2u 01-23-2007 11:14 AM
RE: Poulan 331 Pro
I have identified it as a 31cc high output motor... sounds good at least!
Are these the same motors as Ryobi's?
davewallace 01-23-2007 02:38 PM
RE: Poulan 331 Pro
jrjr2u,
It is a 32cc weedeater/poulan. It has very small transfers and large case volume. It is made better then a Ryobi, but it is much taller.
Dave
jrjr2u 01-23-2007 02:44 PM
RE: Poulan 331 Pro
Better is a good word! Thanks Dave
So how are these compared to say a homelite 30cc?
I understand the Homie is way better than a Ryobi.....
Edit
I just ordered 3 new wt-391 Walbro carbs
One for the Poulan, one for a homie 25 and one for a 30
They are 11.11's so Im hoping they work out ok. The price was right at least!!
jrjr2u 01-23-2007 04:48 PM
RE: Poulan 331 Pro
Are we sure this is a 32? In this post, the alleged 32 is a side carb.
http://www.rcuniverse.com/forum/m_22...tm.htm#2203207
Mine is a rear carb that attaches to the back plate
captinjohn 01-23-2007 07:01 PM
RE: Poulan 331 Pro
That Ryans Rebel looks like a good test plane. May have to build one. Capt,n
mangolo 01-23-2007 07:57 PM
RE: Poulan 331 Pro
Capt,n, I fly a Ryans Revel with a Ryobi 31cc,exelent test bed for that size range.
Waldo
captinjohn 01-23-2007 09:02 PM
RE: Poulan 331 Pro
What is the wing area and the wingspan of the Rebel? Also what is the all up weight? Thanks Capt,n;)
box car 01-24-2007 06:32 PM
RE: Poulan 331 Pro
Was going to post my home built test plane here but think i will start a new thread on conversion planes, who is building what with a lot of pictures
Ken
foamcut 01-24-2007 09:15 PM
RE: Poulan 331 Pro
Ken,
That's a great idea!
Please post the link when you start the new thread.
jrjr2u 02-27-2007 12:44 PM
RE: Poulan 331 Pro
I have found 2 references to this motor and it looks like its a 31cc for sure
http://www.billssmallengines.com/Ven...n_trimmers.htm
How do these compare to the Ryobi 31's power wise?
I'm guessing my time is better spent on a homie 30cc.......
Ralphbf 02-27-2007 12:58 PM
RE: Poulan 331 Pro
I have one of these doing duty as a string trimmer.
I had a Homelite before this one and this has so much more power.
I have ofter thought about converting it.
There are guys out ther who will port these and really bring them to life.
Scott charges $65.00 to do a 25cc Toro the cost should be about the same for this.
http://www.scottellingson.com/
I think this engine has lots of promise.
Ralph
