RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Ryobi with weird carb? (https://www.rcuniverse.com/forum/engine-conversions-92/6415179-ryobi-weird-carb.html)
Flyboywbl 09-26-2007 04:12 AM
I'm doing a ryobi 31 cc weed wacker conversion from wacker engines. com and i was wondering how i set the low and high end needles. I've been looking in alot of fourms about tuning and they say just use a screw driver to turn the screws. My engine's carb does not have screw slots, phillips, or standard, but little wholes not in the center of the screw. I thought maybe a hex screw but no. I don't want to try and jam a needle nose pliers in there and screw them that way do i? Does any one else have this problem? Do i need a new carb? please let me know, any help would be apreciated!!!
thanks
-Matt
av8tor1977 09-26-2007 06:40 AM
RE: Ryobi with weird carb?
Take the screws out and grind a slot in them for a screwdriver with a Dremel tool and a cut off wheel.
AV8TOR
Antique 09-26-2007 09:01 AM
Are you sure your not looking at the little plastic covers used to limit the amount adjustment the user can do ? If so you can pull them off and find the needles under them with screw slots.
Flyboywbl 09-26-2007 10:34 AM
nope not plastic. i like the dremel idea. thanks!!!
