Supertiger 3000
I have been using a ST300 converted to EI and gas for a couple of years. Overall the performance on a "big ol bipe" has been more than adequate. However the life of the small 1/4 X 32 plugs at $15 a pop is less than adequate.
Has anyone tried to tap the head on the large tigers for a 10mm or 14mm plug? |
Plugs
10mm is a snap. All you need is a new plug cap and you must use 2 gaskets on the spark plug.
This will pay for its self about the time you don't buy a second 1/4x32 plug |
Supertiger 3000
tkg,
Would you happen to know the brand and model number of a 10mm plug? Thanks |
Plug
NGK CM-6 , Champion Y-82
RE: Supertiger 3000
has anyone tried to convert a 3000 to 3250 or even know if it can be done?
RE: Supertiger 3000
wvarn1957: What was done to convert your Tiger 3000? What brand of oil and the percent of oil is used in your fuel? thanks Capt,n
RE: Supertiger 3000
Have you priced a liner, piston and ring for a 3250 at tower hobbies?
Scarry. |
RE: Supertiger 3000
First conversion was to EI. Got a syncrospark and walboro carb adaptor from CH. Didn't like the 1/4" Plug so I tapped the head for 10mm. After a few flights the plug blew out of the head and had to make a brass insert in the head for the plug. Later tapped out the insert to 14mm and tried it on gas/glow. Performance was about the same as on gas. Fuel mix was 10% klotz technoplate and rest 87 oct gasoline.
RE: Supertiger 3000
I have a magnum 1800 which I run with Gas/Glow fuel made with 1/3 of 10/10 glow fuel an 2/3 gasoline with extra oil to bring it up to about 8-10 %, some where I read that big supertigre engines can run safely with 6% oil that the extra oil is not needed in fact the big size bushings make the job very well, also morgan fuels makes a blend for super tigre engines that contains only 6% oil.
The engine runs excellent, very good transition, the carb I use is a walbro 9 mm ventury I havent tach it, right now don't have a tach but I love the way it runs. |
RE: Supertiger 3000
Aeronut,
Does the Magnum have bushed rod ends? Thanks |
RE: Supertiger 3000
yes! it's stock and the only thing I made for it was trh base adapter for the carb and a bell crank system for the throttle
RE: Supertiger 3000
What carb are you running on it Bill??
AV8TOR |
| All times are GMT -8. The time now is 12:04 PM. |
