What is gained by adding more expensive Nitro to gasoline ?
Power is the main Reason ? Can I remove the Magneto & fan flywheel assembly completly on my water cooled head in a boat ? Anything other benifits ? I like to simplify if possible. Homelite, old design. Thanks Rich |
RE: What is gained by adding more expensive Nitro to gasoline ?
Pure nitro methane will not mix with gasoline without secondary blending agents. It will separate
Some people blend a smaller amount of model methanol based fuel (that contains some nitro methane) with gasoline in order to sustain glow ignition. This mixture seems to remain stable and not separate. |
Yes it will mix and it mixes great. we run what we call gas/glow. For me and otheres it is the only way to go now. YOu get the best of both world of gas and glow and none of there folts
Paul |
Just to be clearer,
Nitromethane is not the same as calling GlowFuel "Nitro" GlowFuel that we use with glowplugs is Methanol (+oil+nitromethane) You can mix glowfuel with gasoline to run without the heavy spark stuff, it is the Methanol that makes the Glowplug do its thing. I'm no guru, but the sweet mix I see folks using is 2parts gasoline + 1part 'RCCar'GlowFuel(10%oil10%Nitro) in gasoline engines(weedies) with a glow plug in a plug adptor, if you tune the carb rich enough. Side benefit for this boat use is that the glow will run a cooler engine than gasoline. |
2 parts + 1 part = 3 parts or 33 % per part. What happened to the the rest of the RC car Methanol part ? 10 % + 10 % + what ? Rich |
ORIGINAL: cyclops2 2 parts + 1 part = 3 parts or 33 % per part. What happened to the the rest of the RC car Methanol part ? 10 % + 10 % + what ? Rich Well, you could say - one quart of 10/10 glo fuel and 2 quarts of hi test gasoline Thats the same as saying one part and 2 parts..... The size of the part can change but all parts must be equal volume such as 1 gallon glo and 2 gallon gas..... see? |
RC cars have a fuel sold as ----oil 10%..... Nitromethane 10% ? No one knows or cares what the other 80 % is ? I can live with that, if it is true.
Rich |
The rest, less a percentage point here or there for proprietary additives, is methanol. Methyl Alcohol.
AV8TOR |
Does the RC car fuel have enough oil when mixed in the 2 gallons of gasoline to 1 gallon of RC car fuel ? Rich |
Yes it does, i couldn't get the 10/10 stuff that everyone else is using so i used some 20% nitro 12% oil car fuel and mixed it with the premium gasoline and it works fine in my weedeater on the glowplug setup.
The standard mix, as stated above, ends up with approximately a 32:1 oil mix, which is if anything, a touch heavy on oil for gas engines with their ball and needle bearings.
AV8TOR |
OK I have a fresh gallon of the Sig champion fuel.It says it is 10% nitro 20% oil (1/2 Castro&1/2 syn.will this work on the 1 part to two parts mix for my 28cc mac weedy motor or do I have to buy the 10/10 mix???
thanks Clocknut |
That would have WAY too much oil. Buy the 10/10 fuel, or buy a gallon of methanol to add to your glow fuel, then mix it as normal with the high test gas. It will be a little light on nitro done that way, but should work ok.
AV8TOR |
WAAAHOOO ! I am going to do this GlowPlug / 10 %.....10 % fuel stuff. My Homelite without the magneto or coil will easily give me the pound or 2 for the electric starter and choke. I am going with a water cooled head. Old brain....What plugs are good on this fuel mixture. Does it need a low voltage for a good idle ? I have a RAM ELECTRONICS RC switch left over. Rich |
If your mix is right you will not need power to the plug after start up. Run a typ F glow plug.
Paul |
Make sure you use premium gasoline with your mix as some people have had problems with some regular grades, 10/10 works but i have yet to get some and run 20/12 car/truck fuel, as for the glow plug adapter you can either buy one http://www.horizonhobby.com/Products...rodID=ZEN23445 or make one out of an old automotive spark plug as shown here on my engine http://www.rcgroups.com/forums/showt...low+conversion
As mentioned above i use a OS type F 4 stroke glow plug and after the engine has started you can remove the glow driver as you would on a normal 2 or 4 stroke glow engine, make sure you check that when the carb is closed all the way the engine will stop, there's no ignition to kill it. Good luck and have fun. |
| All times are GMT -8. The time now is 04:24 AM. |
