RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   1963 carb (https://www.rcuniverse.com/forum/engine-conversions-92/7266941-1963-carb.html)
geminitool 03-22-2008 08:04 PM
1963 carb
Hi Guys
I have an old chain saw with a marvel schebler tillotson carb. can i get a rebuild kit? if not what walbro carb will work? the saw is a 65cc husqvarna 1963.
Ron
planepounder 03-22-2008 09:36 PM
RE: 1963 carb
Maybe a WT. Are you restoring the saw of converting it?
buck1856 03-22-2008 10:48 PM
RE: 1963 carb
I have a HDA-45A on my 61cc husky chain saw conversion.The only problem is if your going to use it as a saw the throttle linkage might not be the same.You could also use the carb off of a G62.When you look in the intake youll see a stamped number.Mine has a number 42 wich is the venturi size in 64ths of an inch.Are you gonna use it as a saw or RC engine.If a saw i could give ya a few saw shops to check out that i purchase from,send me a pm if needed.
Ralphbf 03-23-2008 12:17 AM
RE: 1963 carb
Hey Buck
I have the same Carb. on my Echo 62cc twin.
Ralph at rcignitions said it was a little small for it.
But I find it runs great and transistion is just super.
I originaly bought it for a 46cc engine I'm building.
buck1856 03-23-2008 09:57 AM
RE: 1963 carb
1 Attachment(s)
The original carb thats still on my 61 twin says HDA-7A,then theres a B5 underneath that.In the intake it says 42S.I have another carb that has an S behind the number>Do ya know what it stands for by chance.Heres a pic of my 61 so far.Mufflers are off a BME100?104?dont remember,bought them off ebay for $29.00 shipped,new,nobody bid on them.So i figured i would.Mounts from a Quadra 42?.
dogshome 03-23-2008 01:20 PM
RE: 1963 carb
I have a similar carb on my Rowena. Tillotson gasket kits are freely available, you just need the number e.g. HS HDA as above. I got mine from ebay.
[link]http://www.rcuniverse.com/forum/m_6764656/tm.htm[/link]
