RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Magnum 180 two stroke (https://www.rcuniverse.com/forum/engine-conversions-92/7563192-magnum-180-two-stroke.html)
Baldeagle 05-31-2008 11:40 AM
I ran the 180 yesterday and it run fine . I forgot how messey two strokes can be. Would it be feisable to convert it to gas? Would I have to put bearings in the connecting rod? I know I would have to get an adaptor for the carb. Thanks Rich
aero nut 05-31-2008 01:37 PM
RE: Magnum 180 two stroke
making an adpter for the carb on the magnum 180 is very easy, just take a 1/4 aluminum plate and drill the holes to match the ones in the carb and the ones in the carburator base on the engine , you'll need to also make a spacer,play with the carb position so it doesn't interfere with it's operation, I converted mine to gas/glow and it worked so good that a friend of mine bought it from me because he liked it so much.
Baldeagle 05-31-2008 07:03 PM
Aero nut That is nice to know. Was there much power difference between the glo and gas? What sparkplug did you use? C&h Ign ? Did you have to put in rod bearings? Thanks I really appreicate it. Rich
