muffler for 26cc toro
I'm looking for a side mt rear dump pitts muffler for a 26cc toro,does anyone know where I can get one.Thank you
RE: muffler for 26cc toro
Ive had 5 25cc toros or troy built and the mufflers that fit the Zenoah G23-G26 have the same bolt pattern.Might have to enlarge holes just a hair with a file on some.I have a stock G23 muffler right now and it bolts up to one of my toro 25cc no problem.
Buck as always you are right on the money.
Hi, I have one of these I'm going to be getting on a plane soon I hope. What carb have you had good luck with? what RPM's have you turned with what prop. Mine is brand new never run and hope to get it going on a test stand next weekend. thanks;)
I'm runnig the carb that came on the engine, as far as rpms not sure but with a 18x6 prop I have 17lbs stadic thrust.I use menzs and evolotion props wood works good for me.
Heres a few numbers that i have used and then ill give ya my favorite one or 2.Ill also give ya the venturi bore.Youll want around 10-11mm.
WT579-9.53mm WT230-9.53mm WT500/WT548/-same carb 9.53 WT289/11.11mm-570/11.13mm-[WT600-628-33111.11mm] I would personally go with the WT600Has a nice long shaft and hook for the choke and has the large triangle shaped throttle arm so you can easily use a ball link or clevis.Its 2 needle as all of these listed are.I was looking at what i have left for carbs and dont remember the other numbers as i sold them on engines.I believe the 600 goes for $12-14 at ecedwards_tools-on ebay.You could do your own checking around for the others if ya want.Might find a better deal.Ive been getting around 68-7200 average with anything from 16x8 up to 17x8.I live at 3000msl.I bought 2 boxes off of the guy on ebay and every engine had different readings even with the same props.You want a prop that puts out good thrust,not just good rpms.I would stay down around 16x8 to break in first. |
Can someone post a photo of one of the 25/26cc Torro engines. Thanks Capt,n
1 Attachment(s)
Heres a few pics of one of mine.I would have some better but im selling one tommorow and will be taking pics the same.This is one of the ones that where selling at 4 to a box on ebay.I bought 2 boxes.These where listed as 25cc toro or troy-built.I called the 800 number to check and they said the same.So there must be a 26cc toro that has the 2 barrel carb on it the brillelli was converting.
Hey Buck,Do You have more of these,thanks
I can make you a muffler if you cant find one.( I do good work :D)
No,i just mailed off my last 2 yesterday.Im going to keep my eye open for more though.
| All times are GMT -8. The time now is 04:01 PM. |
