RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Echo 23.6 (https://www.rcuniverse.com/forum/engine-conversions-92/8007741-echo-23-6-a.html)
bargainbin 10-01-2008 12:24 AM
Echo 23.6
1 Attachment(s)
I have 4 engines to choose from, a Ryobi 31cc, a 25cc Homelite, a Weedeater 21cc and my pick an Echo 23.6. I liked this engine because the crank is supported on both ends it will go in a smaller craft and it is light with that plastic flywheel. After breakdown I find some scratches below the exhaust port and on the piston below the rings. Question is: will these bother this engine.
rangerfredbob 10-01-2008 12:37 AM
RE: Echo 23.6
if there are no scratches above the exhaust port, it should be fine, especially if there aren't any marks on the rings, or if you get a new ring or two it shouldn't care
buck1856 10-01-2008 01:04 AM
RE: Echo 23.6
The echo 24cc is a great little engine.Check out the thread[dont forget echo].im sending you a PM,look out for it.
av8tor1977 10-01-2008 01:37 AM
RE: Echo 23.6
Like Rangerfredbob and Buck said, it's a good engine and if the cylinder isn't scored above the exhaust port it would probably be fine with a new ring. I really like the Echo engines and have a number of them.
I recommend Frank Bowman rings. Just use one of his rings in the top groove, and one of the original rings in the second. Here's his contact info. [email protected], 505-327-0696
AV8TOR
