irvine 40 diesel head fix
irvine 40 diesel (back from the dead)
I have several irvine 40 diesels good rugged engines(EXCEPT) they have the tendency to drop their contra-piston into the cylinder not only does this lower the compression but takes up a lot of space this big brass slug does not compress hence engine ceases to run.I moaned and groaned to Bob Davis of Davis model products (Bob is the leadind guru on this stuff I sent bob the engine and he made a couple of heads for me now up and running , I installed the 2nd head on the second engine before a problem developed with engine #2 they are both in a pair of VMAR appaches running 12x6 or 12x7 wood zingers.so folks if you have and irvine 40 diesel davis has the head ( note this is the old 40 diesel not the new series that are red powder coated) but he has heads for them my new irvines 46 and 53 glows are converted to diesel footnote: the contra piston drop occured at idle and engine just locked and stopped with no damage to rod, cylinder or piston I was lucky :) |
| All times are GMT -8. The time now is 01:03 PM. |
