RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Smoke pump idea (https://www.rcuniverse.com/forum/engine-conversions-92/9441217-smoke-pump-idea.html)
Scota4570 01-23-2010 04:20 PM
Smoke pump idea
Is is workable to use the chain oiler as a smoke fluid pump?
My thought is to use a loop of tubing so that smoke oil is always circulating back to the tank. The valve to the muffler comes in the middle of the loop. A restriction on the return at the tank side of the tee would provide pressure to squirt the oil into the muffler when the valve was opened wih the servo. .
The ECHOs I mess with have a nice looking oiler that I have been removing. This seems like a simple neat way to make a smoke system.
av8tor1977 01-23-2010 10:56 PM
RE: Smoke pump idea
Nice idea, but unfortunately it won't work. The chain oil pump doesn't pump near enough oil.
AV8TOR
w8ye 01-23-2010 11:01 PM
RE: Smoke pump idea
Ude the pump side of an old Walbro carb.
put an outlet tube where the needle and seat normally is
Scota4570 01-23-2010 11:27 PM
RE: Smoke pump idea
Neat idea on the carb pump. Put a tee in the pressure tap line?
I looked up flow rates on chain oilers. I found that one saw runs up to 18cc/min, about 0.6 ounces, at 10K rpm. That is with viscious bar oil. We run slower but the smoke oil is real thin so it should move more? I guess the real question is what is the flow rate of smoke fluid in a real smoke system?
I obvioulsy don't know anything about smokes systems but the guys at the club keep teasing me about it. They all fly little airplanes. It'd be a kick to lay out a smoke trail but I don't want to make a Manhatten project out of it.
w8ye 01-24-2010 01:34 AM
RE: Smoke pump idea
I've had a few chain saws and they didn't set the world on fire with the oiler.
You may never know unless you try it.
av8tor1977 01-24-2010 10:46 AM
RE: Smoke pump idea
On smaller engines, like around 25cc, you need about an ounce a minute or more. Larger engines need more.
AV8TOR
