RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Stihl four stroke models.... (https://www.rcuniverse.com/forum/engine-conversions-92/9494853-stihl-four-stroke-models.html)
av8tor1977 02-11-2010 02:22 AM
Hi,
Does anyone know what all the various sizes of Stihl four strokes are? I have a small Stihl four stroke and I don't know what size it is. I am too busy to take it apart to measure it at the moment, but I am curious as to the sizes that were made. I believe it is a 36cc but I am not sure. It is a bummer that Stihl does not provide any parts or service info on the web....
Anyone have any prop/rpm figures for the Stihl four stroke 36cc??
Thanks in advance for any info,
AV8TOR
jtisch 02-11-2010 01:11 PM
RE: Stihl four stroke models....
There are 28, 32, 36 and 65cc models. The cooling fins are bigger on the 36 than on the 32, otherwise they look the same. I don't have any 28s. I just finished a 36 for a buddy but am still breaking it in and so I haven't tached it yet. It definitely felt more powerful on the stand, though.
Do you know the model# of the weed whacker it came out of?
J
adrian222 02-11-2010 08:22 PM
Here you go.
http://www.stihl.com.au/dspArticleIn...msArticleID=86
Adrian
av8tor1977 02-12-2010 11:01 AM
Ok, thanks guys. Nobody with prop/rpm numbers for various Stihl four strokes? Are they stronger than the Honda GX31?
AV8TOR
jtisch 02-12-2010 12:56 PM
Check on page two for a thread on the 32.
J
av8tor1977 02-12-2010 01:37 PM
Ok, curiousity got the best of me and I took it apart. It is a 32cc. (Bummer, I was hoping for a 36!)
Anyway, you lost me there... Page 2 of what thread?
AV8TOR
av8tor1977 02-12-2010 09:37 PM
Ok, finally found the Stihl four stroke 32cc thread. It appears as though it will have a good bit more power than the Honda 31. That's cool! Maybe when I get it done it will replace the Honda on my Giant Eindekker.
AV8TOR
Nitrohorse 02-20-2010 06:57 PM
I got a FS110R string trimmer for $10.00 from our local lawn mower shop. I came home with it and setit aside. Last weekend I decided to see if it started and it did without muchcoaxing and ran like a champ. Long story short, the crankshaft is barely as long as the flywheel which makes it useless for a conversionengine.
jtisch 02-20-2010 08:31 PM
ORIGINAL: Nitrohorse
I got a FS110R string trimmer for $10.00 from our local lawn mower shop. I came home with it and set it aside. Last weekend I decided to see if it started and it did without much coaxing and ran like a champ. Long story short, the crankshaft is barely as long as the flywheel which makes it useless for a conversion engine.
Yeah, the crankshaft is short, but it can be done:) The crankshafts for the Honda and Subaru/Robin/Fujis aren't much better but again they can and have been done. If nothing else you got yourself a heck of a weed whacker for $10
J
Nitrohorse 02-20-2010 09:05 PM
If the FS110 is used for a conversion, I'm at a loss as to how one can use the flywheel/mag as it's configured from the factory. The only way I see
to use the engine is to useaVERYshort prop hub with an electonic ignition.
jtisch 02-20-2010 09:17 PM
It surely is a good idea to keep the hub short, but I am working on a solution for that so I can have a longer hub. I have done about a dozen 32s now (both mag and EI )and in MHO, they aren't too shabby. They are compact, run inverted, and have decent power.
J
Scota4570 02-21-2010 12:44 AM
1 Attachment(s)
I've never seen one but, could you make the hub so that the prop shaft fits inside the hub and over the end of the crank? Possibly some variation of the attached photos? Using this method the par tof the hub that fits ove the taper could be little more than a thick washer.
av8tor1977 02-21-2010 01:20 AM
Of course you can. The short shaft Ryobi conversion kits are done similar to your photos. Where there's a will there's a way! I would probably just make up a hub with a taper that screws right onto the shaft however....
I never run magnetos.
On a four stroke, you can just use an electronic ignition for a two stroke. It doesn't affect a thing that the plug also fires on the exhaust stroke. I have my Honda GX-31 four stroke set up that way.
AV8TOR
Nitrohorse 02-21-2010 06:11 AM
I have a Ryobi 26cc 4stroke on the bench alongwith the Stihl 4 stroke.The Stihl hands-down has much more power and rpms. I guess I'll have to fireup the lathe
and make a shaft extension so that I can use the factory mag with it. I don't have weights for each of the engines, but it appears that the Stihl is noticeably lighter. I also like the
fact that I don't have the added weight of engine oiland a sump to deal with like the Honda and Ryobi.I know that my local lawn mower shop has afew more of the Stihl weed whackers available, so
I might buy one or two more if this conversion is successful. He's a Stihl dealer and is more than happy to sell me what heconsiders "junk". I seen that he has two shelves full of dead chainsaws, so Iguess I'll have to check them out on my next visit.
Where is a good place to buy an electronic ignition? Maybe I need to come out of the stone age and try one...lol.
Larry
Tauri Flyer 02-21-2010 09:07 AM
First ,,I HAVE ten dollars ready for that sthl 4 stroker,,,so if your not gonna use it!! Second,,ah ya wouldn't mind introducing me to that sthl dealer would ya! ;-)
:eek:
av8tor1977 02-21-2010 11:03 AM
www.ch-ignitions.com
AV8TOR
Nitrohorse 02-21-2010 06:30 PM
Tauri Flyer,
I'm pretty sure I'm going to use the Stihl..I can't tell you who I buy these from, I would be creating needlesscompetiton for myself.
Nitrohorse 02-21-2010 06:31 PM
ORIGINAL: av8tor1977
AV8TOR
Thank you.
rangerfredbob 02-22-2010 12:59 AM
another good place is the marketplace here, there's a RC EXL ignition on there almost all the time for around $60
Scota4570 02-23-2010 11:03 PM
Does anyone sell short blocks or refurbished units? The Stihl FS 130 looks perfect for my 1/4 scale D-7 project.
jtisch 03-06-2010 02:24 PM
Stihl dealers will sell you a short-block. A new 36 at my dealer was @ $185. Keep in mind there is no mag ignition,carb or manifold, but if you go with EI you don't need the mag anyway.
