RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   plane,thrust?????????? (https://www.rcuniverse.com/forum/engine-conversions-92/968974-plane-thrust.html)
buck1856 07-18-2003 03:06 AM
how do you come up with how many lbs of thrust you need for your plane? for instance,if you have a 12 lb plane empty, no radio gear or anything, what size engine would i be looking for. do you just use a standard scale like a 70 to 90 or is there a way to refine this a little bit. or just ask on rcu. thanks
w8ye 07-18-2003 03:53 AM
Hook a fish scale to the rear of your plane and see how much pull it has? It will take in excess of 12 pounds pull to hoover a 12 lb plane.
You can also use the thrust calculator program to calculate thrust if you know how many rpm's a certain engine will turn a certain prop.
Enjoy,
Jim
buck1856 07-18-2003 07:10 PM
what is a thrust calculater program and where do you get one.
w8ye 07-19-2003 02:25 AM
http://david_ironsides.tripod.com/ir...raft/id15.html
You will have to download and then install on your computer.
Enjoy,
Jim
buck1856 07-19-2003 02:59 AM
thanks a lot for the help.
