HBK2 battery? Brushless
CA
I just got the Esky 3800 brushless motor and 25a esky ESC and was wondering whats the best battery i can get to match up with it and balance the heli? Like what C , Mah, and volts?
Radley
Radley
RE: HBK2 battery? Brushless
well you're gona want to go with a 3s lipo, or 11.1v, atleast 1300mAh and atleast 10C depending on the battery size. If you go above a 1650mAh battery you can go with an 8C pack. 1300mAh 10C pack can do 13A, and a 1650mAh 8C pack can do 13.2A continuous draw.
CA
How about on of these would these work ?
https://www.unitedhobbies.com/UNITED...idProduct=2096
https://www.unitedhobbies.com/UNITED...idProduct=2095
yeah, either of those should work. I'm not sure what the stock pack weighs, but you'll want to consider that as well. Make sure that the over all additional weight you have on the heli isn't over about 10% above stock weight.
