V4 problem
Hi all,
Just got my lovely v4, it's fun to fly around my room!
But i have a problem of with the rudder. My v4 will rotates counterclockwise (not that serious) no matter i fully pushed the fine trim on transmitter or turned the proportional adjustment on receiver.
Is this normal? i reckon i should be able to find the neutral point by adjusting the proportional but it seems like it needs another half turn from the dead end to reach neutral point!
Anyone faced the same problem as mine? if you do what would you recommend me to do?
Thaks in anticipation for your help.
regards
roy
regards
roy
QC, CANADA
ORIGINAL: roychye
Hi all,
regards
roy
Hi all,
regards
roy
Here is what I was doing, first I would hold the V4 in my hand safelly away from me and then turn off the transmeter, I would then push the rudder trim to the far left and then turn the Transmeter back on always making shure holding the V4 wait for the green light and now you should have lots more rudder trim available, it worked well for mine
