G3.5
Fellows I dont/cant find a sim forum so I will post here or whereever you fellows suggest. I got a G3.5 and have it up and running, my question is: Is there a way on the g3.5 to get dual rates on the stock xmiter that comes with this sim or by modifing the aircraft software, it sure would help if I could do this, thanks, Mike
Here's a link to the RCU SIM forum.
http://www.rcuniverse.com/forum/forumid_138/tt.htm
The G3.5 "InterLink Plus" feature allows interfacing with most transmitters so, if you have a Tx with dual rates or TVA/EPA you may want to look into interfacing it with your SIM. However, I'm not sure if dual rate or TVA/EPA features work with G3.5. You may want to post your question on the RCU SIM forum for more advice on this. I assume that you want to reduce the rates so as to slow the reponse down and, if so, you can sometimes do this by extending the length of Tx control sticks. Some Tx sticks have an adjustment for this and some do not.
Good luck and good flying!
