HELP! Please on replacing the inner shaft
WA
Can anyone tell me how to replace the inner shaft on a E-Sky Robbins 22 ?
Thanks for any help you can provide, this is my first Heli .
Alan
Alan
Just loosen the two grubscrews in the aluminium hub of the lowest gear, and the shaft - including the upper rotor head - will lift out.
The blade holders on the rotor head dismantle by unscrewing the two screws on top and slide apart.
Be aware of the two flats at the bottom of the shaft. Ensure that the grubscrews of the gear hub align with and tighten onto these when replacing the shaft.
Also be aware that there is a ball bearing in the hub of the upper - outer shaft - gear. It's possible for this to fall out when the lower gear is removed. There may also be a washer between the two gears.
You will probably have to remove the battery holder and, maybe, the landing gear to gain easier access to the gears.
WA
ranavalona,,,, Thanks for the information , I should be able to handle this , it doesn't sound to hard .
Thanks again
Alan
Thanks again
Alan
FL
http://www.rbgrn.net/blog/2007/08/ho...ner-shaft.html
How to replace a Blade CX2 inner shaft - Robert Green's DIY
