spinning counter clock out of control :
Hey gentlemen i am noob ihave hbfp with crash kit installed and when i try to fly it spins way out of control cc wise i,ve tried to adjust the pp trim& even the gain does not help any help with this would appreciated thanks.
RE: spinning counter clock out of control :
The heli will spin CC because of the torque from the motor (if you held it by the blades and turned it on it'd spin CC, DO NOT ACTUALLY DO THAT ), but the tail rotor should be keeping it from spinning like that so.. is the tail rotor spinning when you increase throttle? Does the tail rotor increase in speed when you throttle up? When you first plug the battery in, your trims are set in the middle right? And you are waiting for the light to stop blinking and go solid green? And you aren't moving the heli after you've plugged it in, before the light isn't blinking? Sorry for all the dumb questions but need more info
AB, CANADA
either the tail rotor isn't working or the gyro is set to the wrong setting. try reversing the gyro nor/rev switch.
thanks nutcraze and druss i found the problem, i was making a new skid for it to attach my crash kit to so i would not mess up my org. i as stupied as i am, i plug the tail motor in rev. dumb i know but at least i am honest,nutcraze i liked your vid. on rotor head mod thanks to people like you it is going to make this hobby alot more fun any way thank you guys for the help.
