Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
tracking problem...
Old 02-08-2008 | 04:19 PM
Default tracking problem...
Hey guys,
I just started to have a blade tracking problem. At lower RPMs, about 30% throttle, I have the tracking spot on. I increase the throttle to just below hover and one blade just shoots up. When looking at it from the side, it is about a quarter inch to a half an inch. What is causing this?
Thanks for the help AGAIN guys!
Old 02-08-2008 | 04:21 PM
Default RE: tracking problem...
Well Solo you need to track the blades while in a hover when they are under a load. Then if they are out a little bit on spin up it will not matter. Probably one blade is a little more flexible than the other. No Biggie. Gittle
Old 02-08-2008 | 04:43 PM
blk822's Avatar
Gittle is right track you blades at 60 to 70% throttle. Doesn't matter how they track on the ground.It's in the air you need to worry about.
Old 02-08-2008 | 04:58 PM
Alright guys. Thanks a lot for the info. I just wanted to make sure that a part wasnt getting fatigued or something.
Thanks!
Old 02-08-2008 | 06:59 PM
kenhiraihnl's Avatar
i agree with all of the above...i know this might not make sense, but if you're using woodies, install a nice, balanced set of carbon blades ($30)...you'll know if the variable tracking problem is sloppiness in your spindle/grips...besides, it'll give you a reason to buy something nice for your hbk2 -- even if it's not quite ready for it yet...lol...ken
Old 02-08-2008 | 09:53 PM
I'm having the same problem but I also checked tracking in idle-up mode. The blade that is higher on positive is lower on negative. If I track the blades better for positive pitch, the negative is way off. Any ideas?
Old 02-09-2008 | 03:58 AM
Look for any excessive slop in anything from the swash up. Any slop more than a couple hairs of movement is excessive. I had some wiggle in the washout arm where it screwed into the washout. Replaced it with the purple one, and tracking immediately improved.
Old 02-09-2008 | 07:14 AM
To shizack's point, and I'm going to assume you've already verified the feathering shaft is straight. One sneaky place slop can creep into the setup is through the flybar pivot points. Chances are if you've crashed & bent the feathering shaft, you've broken a pivot as well. It’s hard to see, but the test is easy. The flybar is supposed to pivot up & down in the vertical plane but there should be no play in the horizontal plane. So, hold the main blade grips still & try moving one of the flybar paddles from side to side. If you observe movement/play, then I’m betting one of the pivots is fractured & it (the flybar center holder, item 15, pg13) needs to be changed out. It will definitely make a difference in setting the tracking.
(A word, not from the wize, but from the experienced)[sm=wink_smile.gif]
Old 02-09-2008 | 07:54 AM
Also Chris if you are flying 3D and using wood blades you need to change to a bettter or more ridgid blade. If you are not flying 3D yet and still just flying around without using any negative pitch then don't be concerned about the negative. Track you blades for hovering in Idle up and go for it. If you do a loop or a roll once in a while you will need to think about some better blades. Do as Jh1947 and shizack recommends. Thoroughly check out that head and make sure it is in tip top shape especially if you going inverted.
Always remember, Man who fly upside down have nasty crack up.
Old 02-09-2008 | 05:08 PM
Thanks guys. I checked everything and it looks OK. I loosened the feathering shaft nuts a little because they seemed to be too tight according to my research. There should be a small gap between the hub and blade grips to allow a little pivot, right? The only thing I see is that the entire head has a little slop in every part. I guess it all adds up. I'm just hovering right now so the woodies are fine and tracking is OK at these speeds. It hovers quite nicely and the tail stays so I guess it'll work for now. The reason I noticed the tracking problem in idle-up is I was setting up my DX-7 with it. Maybe the 50% throttle with 0 deg pitch is too much speed with the motor I'm using. It's an Align 430L 3550Kv with an 11T pinion. Maybe a 10T would be better or maybe I need to adjust the throttle curve lower than the stock TX. Normal mode is fine. If there is a poorly manufactured part in there somewhere, I'll probably break and replace it before I ever try inverted. I already broke one set of blades last night cause I thought I could do some slow turns in a small place. Believe it or not, the feathering shaft did not bend. Thanks again for your help.
Chris
