Whats in your HBK2?
MI
Whats in your HBK2?
Not sure if there is a thread out there for this so I thought I''d try it. Lets see what everyone runs for making their HBK2 as fun as possible.
Upgrades:
3800kv + 25a ESC (ESKY)
11T pinion
Telebee HHG
1500mah 15c x2 (ESKY)
43t pulley Extreme Productions
Align Trex 450 skids
HDX450 tail blades
Extreme turnbuckles (great for setting up your tracking) Recommend these!
Spektrum DX7 + AR6200
Acces:
ElectriFly PolyCharge 4
Micro-cam mounted in the canopy to give it a ''cockpit'' view
40a toggle switch for tweaking and setup. ( nice not having to unplug battery every time.)
Upgrades:
11T pinion
Telebee HHG
HDX450 tail blades
Acces:
RE: Whats in your HBK2?
Here''s my set up, aquired in mid-February this year - very similar to yours! My first RC anything.
Upgrades:
Acces:
Stock chargers
Stock controller
Rob
Upgrades:
Acces:
Stock chargers
Stock controller
Rob
FL
here''s mine.
3800kv
25a esc
esky hh gyro
s75 servos all around
2100mah 20c lipo (esky)
2 led''s kit
flys like a champ. except in 15-20 winds.
3800kv
25a esc
esky hh gyro
2 led''s kit
WI
Barebones
HDX300 4200 KV brushless
25 amp Esky ESC
1350 mah Kong Power Lipo
Telebee HH gyro
Xtreme 43T tail pulley
Xtreme Frame stiffener and battery mount
4 Hitec HS-55 servos
Esky stock RX
Futaba 6EXHP TX
Custom airbrushed Trex canopy
25 amp Esky ESC
Telebee HH gyro
Esky stock RX
Futaba 6EXHP TX
My Feedback: (27)
WI
Upgrades:
3800kv + 11T pinion
25a ESC (ESKY)
1500mah 15c (CSRC)
Telebee HH Gyro
Hitec HS-50 Tail Servo
Hitec HS-45 Collective Servos
Spektrum 6100E Receiver
JR 8103 Tx with Spektrum module
3800kv + 11T pinion
25a ESC (ESKY)
1500mah 15c (CSRC)
Telebee HH Gyro
CA
looked like fun so here I am...Again!
3700 Hyperion
30A Dynam
Telebee HH Gyro
B400 main Gear
Eflight 11T pinion
Trex batwing tail rotors
Trex 600 Skids
Helimax 275mm CF Blades
1350 Mega Power
Homemade slanted battery tray from motor
Pigeon 450 canopy
stock everything else....
3700 Hyperion
30A Dynam
Telebee HH Gyro
B400 main Gear
Eflight 11T pinion
Trex 600 Skids
1350 Mega Power
Pigeon 450 canopy
SC
300HDX 4200kv motor
Dynam 30 ESC
HobbyWing UBEC
Eflite EC3 battery connectors
Standard SuperSkids© with Align skidstoppers
Full CNC head
CNC tailbox
Align HS1176 tail blade holder
Full Esky carbon frame conversion
Telebee 6g gyro
JR SM22 cyclic servos
JR S185 rudder servo
MX400 vertical and horizontal fins
Spektrum AR6200 RX and satellite
Spektrum DX6i steering wheel
The list of stock parts remaining on King Arex II is actually shorter.
Dynam 30 ESC
HobbyWing UBEC
Full CNC head
CNC tailbox
Telebee 6g gyro
WA
I''m running :
Esky 3800kv motor
Esky 25 amp ESC
11 t pinion
Xtreme 43t belt gear
Trex 450 tail blades
HiTec HS-55 collective servos
Tower pro tail servo( hitech was damaged in a crash)
Trex 450 landing gear
Trex fiber glass canopy ( I painted myself)
Telebee HH gyro
couple of CSRC batt.
Made a Aluminum battery tray
CopterX V2 Aluminum Head
Using a Futaba6EXHP radio and HiTec Rx
Have a Dynamite peak charger and Eqinox Balancer
Esky 3800kv motor
Esky 25 amp ESC
11 t pinion
Telebee HH gyro
WI
I'll jump in on this. Here's mine.
HBK2
E3 Enterprises 3900kv motor w/11t pinion
E3 Enterprises 25amp ESC
Blade 400 main gear
43 tooth belt conversion
Esky hh gyro
CNC head and tail box
3D X400 blades (290mm)
Esky Bell 222 fuselage
1600mah lipos
HBK2
Blade 400 main gear
Esky hh gyro
1600mah lipos
FL
this is my HBK2 will add pictures later there on home computer
ESKY 3900 with 10 tooth pinion
hobbywing 30A ESC
HITEC HS-55 servos
super skids
CF tail boom
CNC tail servo holder
COPTER X V2 head
ESKY CNC shash plate
CNC anti-rotation bracket
43 tooth upgrade
COPTER X V2 cnc tail assy
plexi glass battery tray extension
450 tail blades
288mm FRP main blades
telebee hh gyro
DX7 TX
6100 RX
removed z bend linkages now all ball links
hobbywing 30A ESC
HITEC HS-55 servos
super skids
CF tail boom
COPTER X V2 head
43 tooth upgrade
450 tail blades
telebee hh gyro
DX7 TX
6100 RX
I just got mine in the air. It is just a simple plastic $90.00 to the door bare bones helicopter. I have a Gunther 3800 BL with 9 tooth pinion, (3) high torque digital MG servos (1) high speed digital mg servo for the tail, 240 gyro, 1250 mah lipo, flown with a RD6000, stock wood blades.
I may end up getting a nice aluminum tail for to get a little more throw in the blades.
Dru.
Dru.
WI
OK, sorry this isn't longer but if you read "head hold gyro won't hold...why?" You'll see my issue. Other than that many people have asked to see my King2 with Bell 222 fuse fly, well will a short hover work? It was raining and windy out side so I was inside the main hangar for a short hover, also my camera sucks and shut itself off after 30 seconds. Well enjoy. S
http://www.youtube.com/watch?v=dtA2S2Oy6fk
P.S. I forgot to mention in my list of mods a cnc anti rotation bracket and Xtreme adjustable turnbuckles, for nice blade tracking.
MI
Which of these set-ups, mainly gyro/ tail servo, would be recommended to do mild 3D. I want the HBKII to be a cheaper trainer than my T-Rex.
Thanks All and God Bless,
Jay
Jay
MN
Posted: Sun Jun 01, 2008 11:39 pm
Post subject: boy,O boy, I am stunned.... Quote Edit/Delete
Hey you pilots/heli pro's etc.
Man I am stunned at whats going on with my HBK2 I replaced stock motor esc and also installed hh gyro. I have the 3900 KV with the 10 pinion gear, the only thing I have not replaced is the Tx, for cost reasons, and stock batt, when i plugged every thing in I have esc to 2 pin set, I also plugged the hh gyro according to the setup Vid on you tube, kinda confused because i read someone saying the orange plug need not be plugged? also when i first lit Her up, the hh gyro did make noise not so much a blip, but more like gears moving and had a blue lite, but when i advanced the throttle nothing, so I shut er down, and tried to recharge stock batt, all I get there is a red lite, and upon yet more research, i guess the lipo dropped beyond recharge range. Oh, the motor acted like it wanted to turn at first but nah!
anyway to make a long story short, I am wondering if anyone has an up close diagram of placing plugs in pin connectors on receiver, and power requirements again all I have is the stock Tx and little knowledge with advanced setup just going with what I have read or seems to be correct based on combining various studies. its a bit rough without a pro ta kinda guide me, p.s I attached my motor backwards like the one shown had to cut away a little material just has shown, all connectors seem right, just wondering is it mearly a pwr. issue? what battery is recommended all i have is the 11.1v charger frm esky.
also when i put the gear on i could only get it flush and there is'nt much room for adjustment once i screw it down to frame but it truns freely and gears mesh well. thank's sorry bout all the text!
_________________
Bigrick
Rosebud disregard the headin, how'd you add the pic's have'nt had much success with this area, but yours is cool, i'm tryin ta repaint my canopy also i will try ta add photos this reply, also need help am still green in this arena![8D][X(][8D][img][/img] my HBK2 is the yellow has you can tell by the rotors, I also want ta get walkera 60 290mm main blades I heard they are an exact fit, wonder will they not cause boom strike? or do I if gettin em have to get longer boom? if thats the case fo-get-about-it! pls. write me with your experience n some helps if possible, will also accept any gas heli donations in at least workable condition, my dream is to do at least one scale model someday!
_________________
Bigrick
CA
ORIGINAL: bigricksharpe
_________________
Bigrick
_________________
Bigrick
No wonder that thing won't fly. It has ugly duckling syndrome and wants to be put back in the closet!!!
Z
MN
UH... I missed that thread will look for it! kinda new here and now i see how ya do these, will keep Q&A in Q&A forums has much has possible, has for the paint, I am changing the look once more, dumping the engine blue for a cooler color, wet sanding the gold has well not done yet lol
CA
Repost a picture when you are done with the paint Rick! I was just having fun anyway, if the heli flies, that is all that matters to us Esky'rs..
Peace,
Z
Peace,
Z
HI
Here’s the Non-OEM stuff I’m running:
Esky 3900kv motor, 10t
Esky Alum Swash and Washout assembly
Esky CF Vertical Fin and Clipped Horiz Fin
CC Phoenix 25 amp ESC
Xtreme 43t Pulley kit, Anti-rotation bracket, Turnbuckles, and Head button
Trex 450 tail assembly and blades
Trex Spindle Mod
Fut S-3114 tail servo/CF pushrod
Fut GY240
Fut 9CHPS w/ TM-7 and R607 Rx
TP3s1320 on slant battery tray
Radio Shack 30 amp Power Switch
btw, a little off-topic, but the flight maneuvers performed by the 'red bull' should be easy to do with a mildly modified hbk2...ken
http://www.youtube.com/watch?v=RGu45...eature=related
Trex Spindle Mod
Fut GY240
ORIGINAL: Zimatosa
3700 Hyperion
30A Dynam
Telebee HH Gyro
B400 main Gear
Eflight 11T pinion
Trex 600 Skids
1350 Mega Power
Pigeon 450 canopy
3700 Hyperion
30A Dynam
Telebee HH Gyro
B400 main Gear
Eflight 11T pinion
Trex 600 Skids
1350 Mega Power
Pigeon 450 canopy
those trex 600 skids are really cool!!
is this what you got??
[link]http://www.xheli.com/landingskidset.html[/link]
