Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
CNC SETUP
Old 02-19-2009 | 03:40 PM
Default CNC SETUP
When you install cnc head do you have too reverse throttle on tx. I was setting pitch when I realized when throttling up the swash goes up setting negative pitch and of course when lowering throttle it goes down setting positive pitch ???
Old 02-19-2009 | 03:49 PM
Default RE: CNC SETUP
you have your blade grips facing the wrong way
Old 02-19-2009 | 04:54 PM
I put it together like the manual I found on the internet told me too. Do you mean put the left grip on the right side and right on left ????
Old 02-19-2009 | 05:16 PM
take them off the linkage and flip them over the other way. since they are simmetrical doesnt matter which is right or left. its the position of the linkage from the leading edge of the blade grip. i hope i'm being clear[sm=50_50.gif]. if you stop and think about it you'll understand.
Old 02-19-2009 | 05:22 PM
I am so damm stupid your right not only that but it started when I put the flybar holder upside down lololol now I have to break the screws and re locktite this is what you get when you do not take your time
PS Thanks Noob you da man
Old 02-19-2009 | 05:29 PM
np. glad you get it.
