Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Esky Helicopters
 king 2 radio programming >
Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
Old 05-02-2009 | 02:18 AM
Default king 2 radio programming
i have a futaba 6 exh heli radio and just bought a rx ready king 2 problem is i have no idea how to program it
is anyone using this system with the king 2 and if so can i get some help with the setup i need someone to guide me thru it as im not understanding from reading the manual
none of it makes sense so im in need of some help i will set this heli up for sport flying so i will just need normal and idle up 1 settings im guessing
the previous owner is sending me the settings he used with dx7 but if that helps idon t know
thanks for any help guys im grounded until i can get it programmed
divr6347
Old 05-06-2009 | 01:58 PM
Default RE: king 2 radio programming
I have the same set-up. I used the settings posted here: (http://www.heliguy.com/Forum/futaba-...de-t38084.html) and they worked well. I increased the swash mix on "E" and "A" to 60%, but I would recomend you start at 50 and see what feels right to you.
jim
Old 05-07-2009 | 11:58 PM
i would like to check it out but the link does not work took me to another search engine
divr6347
Old 05-08-2009 | 01:21 AM
pilot143's Avatar
link worked fine... but wanted me to register to read it... no thanks... otherwise I would have posted results here.
Old 05-10-2009 | 11:43 PM
Email me ([email protected]) and I can send you a .pdf file of settings I got from someone on a message board a while back. They seemed to work and I may of adjusted them a bit, but it should be close enough to get you in the air. Jeff
