RCU Forums
-   Esky Helicopters (https://www.rcuniverse.com/forum/esky-helicopters-481/)
-   -   20 min. hover (https://www.rcuniverse.com/forum/esky-helicopters-481/7537103-20-min-hover.html)
HowNot2fly 05-24-2008 11:52 PM
20 min. hover
well,i bought the 2200mah lipo for my hbfp but i`m still waiting for some other parts,since lama is the only heli in my fleet that flys right now i decided to stick the big batt. in it and see if it would take off,not only got up in the air but it hover for 20 min., i know its pointless but i guess i got nothing better to do till i get the other helis working:D
homeunt 05-25-2008 08:39 AM
RE: 20 min. hover
lol, how can ur little fp lift off with thick and heavy 2200mah?
nuttcaze 05-25-2008 10:42 AM
RE: 20 min. hover
nah he was using a Lama [X(]?!?
Stil amazing it would even lift, motors must have been super hot afterwards, you would think
DumbDawg 05-25-2008 10:48 AM
RE: 20 min. hover
How the smeg did you get the battery onto the Lama??? I am totally AMAZED that a lama would even lift off. But seriously, did you duct tape the bat to it???
HowNot2fly 05-25-2008 11:02 AM
RE: 20 min. hover
the 2200mah 2cell lipo from thunder power is about the same size as the stock 800mah just much longer,so it does fit in the tray half way,it was very nose havy,full stick back almost the whole time:D,the motors were warm but not hot and the batt was cold,man my thumbs were about to fall off after 20 min.[sm=thumbup.gif], i would make another crazy vid but i think it would be boring watching lama hover for 20 min.
funflier 05-27-2008 03:26 AM
RE: 20 min. hover
those little co-ax can lift about anything, counter rotating blades increase the lift about 50% or more I understand. In one of our LHS they had a co-ax flying around with a 2800 ma battery velcroed under it. Actually was a Cx-2 but they use the same motors. looked akward but it flew pretty good.
vega2614 05-28-2008 01:15 PM
RE: 20 min. hover
My Lama can't even haul the stock 800mAh battery anymore. I just get ground-effect hovering. It must be a bad connection or 4-in-1, because the trimming hasn't changed (ruling out a bad motor). I have been using an 11.1V battery lately and the Lama has amazing power. I'll try and post a vid. Of course, the motors will burn out eventually...
HowNot2fly 05-28-2008 03:42 PM
RE: 20 min. hover
cool[8D],i want to see lama on 11.1 v:D
funflier 05-29-2008 01:57 AM
RE: 20 min. hover
thats the giveaway that the motors are gone is when the little Llama won't lift off due to low rpm. You dont hear it but it only has to drop off a little. This is only true if your battery is fully charged. You may want to check the peak voltage on your battery after charging it. Should be about 8 - 8.4 volt.
LateApex31 05-29-2008 06:22 PM
RE: 20 min. hover
I flew one of my relatively low hour Lama V3s last night with a 3S 1300 MAh battery in it. It flew pretty well and had insane (really insane) power. The only thing I noticed is a greater tendency to yo-yo, but that was probably my dumb thumbs. I could also get some super high speed straight line flight, although with stock shafts it did like to wad up during hard cornering (duh this isn't a CP bird). After 3 or 4 5 minute flights it went into a hard left spin although I set her down with no damage (the battery stuck out past the landing skids!). I didn't check it out but I imagine that a motor or 4 in 1 burned out. No worries, that's why I have a spare parts bird!
HowNot2fly 05-29-2008 06:43 PM
RE: 20 min. hover
is it 1300mah 7.4v or 11.1v?
LateApex31 05-30-2008 12:07 AM
RE: 20 min. hover
3 cell (11.1V nominal)
