Go Back  RCU Forums > RC Airplanes > Events, Shows and Fun Flys - Airplanes
Reload this Page >
How Do You Flat Spin A Limbo Dancer?
Events, Shows and Fun Flys - Airplanes Discuss details of events, shows and fun fly's in here. Be sure to also list events in our events calendar!
Old 03-02-2003, 02:03 AM
acropad
Default How Do You Flat Spin A Limbo Dancer?
Basically i dont no how to flat spin so if anybody could give me a detailed view, pease do
thanks - paddy
ps pm me if you can please
Old 03-02-2003, 03:31 AM
SNestle
Acropad,
There is more than 1 way to induce a flat spin. Also, your plane has to be properly balanced to make the spin truly flat. Otherwise it's just a regular spin or spiral. To get to the proper balance point I gradually add tail-weight to the point where I can still get the plane out of a flat spin safely. If you go to far past that it makes for a flat crash.
Here's how I do it with my CG Ultimate; Climb really, really high; from straight and level, reduce throttle to idle; slowly add elevator until the plane stalls; immediately after the nose goes down apply full left rudder, aileron and up elevator; as soon as it starts to spin move the aileron to neutral; it should begin to flatten out, if not, add a little right aileron. So, your rudder will be full left, elevator full up and aileron's to the right. THis is called cross-controlling. To some extent the more right aileron the flatter the spin. With some planes you can actually stop the spin if you go to far to the right.
