2nd FP 10 up and ok
2nd FP 10 up and ok
Got the 2nd one up with Bobs head and the socket head 2.5mm screws to secure it I made have stated 3.5mm for the screws in error they are 2.,5x 8 mm
small issue the black plastic arm on the carb broke when I was putting one the EZ connector anyone have an other one?? martin
the carb is fine just need the black plastic arm , the engine is fine compression good went right off on a carb prime
RE: 2nd FP 10 up and ok
Chris too make sure the holes were deep enough ran a 2.5 mm tap thru, not really needed just a check the 2.5 x 8mm perfect fit and you can get them firmed down
nice and tight , both engines done the same. I just repaired the broken throttle arm by slipping a thin piece of aluminum tubing over the broken arm slipped in the broken part flattened with a plier use some ca glue to fill the gap and glue and it works the EZ connector was then put on, looks sleezy but it worked would like to get a new arm however martin
footnote I put the screws in the casting ( no head) and they went right to the bottom so length is right
1 Post
Good then, because 2.5mm fit in a 2.6 hole (obviously!)-but you run a high risk of stripping the thread when you tighten them because of the low thread engagement..............
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
