Minnie Telemaster engine change
The old minnie telemaster needs some cosmetic fixup, replace some covering on front and bottom, looking at the mount it is now wearing an OS FP10 Davis conversion, checked my enya CX11D same mounting pattern and never in a plane, so we are swapping engines, drop in fit and will swing a 9x4 to 9x6 prop, the Enya needs some fresh air, sitting on shelf for years, mounted a 9x6 hand holding 5 or 6 flips with Davis ABC fuel and off it went martin
Post note the OSFP10 has a home going in a J-3 cub
