Break in for a chromed engine?
Hi Again:
Is there a good method to use when breaking in a chromed engine?
Today, I got out my old ST G20/15D that has had the bore and the crank pin chromed. I ran it on a large 10x6 prop to get at a very undercompressed condition and as rich as it would go and still continue to run. I did this for about 4 minutes and then switched to an old Cox 8x4 gray prop. I ran this for about another 5 minutes to start the break in process a and to find starting settings for running. I ran this prop at an undercompressed and rich condition that was recorded to be 14,000 plus rpms.
What should I do next? What I want is a sport engine that is very easy to start after I break it in. How much more bench time do I need on this engine?
Any suggestions?
Tia,
Franchi
Any suggestions?
Tia,
Franchi
fly it like you ran 'til now, then slowly adjust to leaner mixtures. Be sure to have lots of oil in the fuel. (at least 25%)
