Need help to convert MP Jet
HI
This is my first try to convert to diesel
Please help if any one did it to this engine.
This engine have kind of special plug that go in the cylinder.
Yuval
Yuval
RE: Need help to convert MP Jet
Did oyu use the old plug ?? or made a new cylinder hade?
What the moving distance I have to make?
ORIGINAL: barkai
Make a new cylinderhead in duraluminium or steel if it is smaller parts and contrapiston in aluminium or steel and can have 1 or 2 O-rings dependent on place in cylinderhead cause small engine. Surfaces in cylinderhead and contrapiston shall be smooth to prevent damaging o-ring. Contrapiston with O-ring shall be very tight mounted in cylinderhead.
Moving distance in contrapiston 4-5mm.
Jens Eirik
If it is the 061 you can buy the head from Carlson imports USA , just bolt it on MPJet Factory diesel head, or as motorboy describes
you can make one
you can make one
They may have changed things, and I agree that you may find it much simpler to just buy a proper head but on my Jets Diesel, you also need the longer cylinder that carries the contra piston. A matching piston may be required as well.
