PAW 80
Hi, i has received the engine PAW 80 and the cylinder are difference from modern PAW 0.80/0.49 and carburator are not vertical, it has 3 screws at cylinderhead, stamped "80" inside backcover. I belive the engine has not ball bearing.
The engine has good compression.
See at the photo..
Which year the engine was produced?
Jens Eirik
See at the photo..
Jens Eirik
Jens I just pulled out my factory sheet that come with paw props they say to run for 033.049.06 all the same max 8x4 run in 7x4
min 5x3 they also list castor % running in 30%, fully run in 25%, BR (single BB) 20% , TBR 15% (racing and speed only) for long life I do not think I would go lower than 20% on the oil martin
