PAW .06 props?
My Feedback: (10)
GA
Whats the best overall prop for a paw .06? Whats the biggest prop that I can run with out over loading it?
My plane should come in about 20 to 22 ounces RTF hopefully less. Fuse wing and tail is 9 ounces with a 270 sq in flat foam wing 12 inch root 6 inch tip chord. Dont worry i taped the wing so the fuel wouldnt eat it.
CA
7x3 is a good size. I've been flying my PAW .061 a bunch lately. I use my "Baker Black Brew" mix: see the tested fules thread...
Actually I've been sanding my prop down a little and if they made a 6.5 x 3 I would give it a try but they don't make one. 6x3 would be too small I think.
Hi Grant
I've run 7 x 3 and 7 x 4's on my PAW 06 but the one that gave me the best results was a Cox 7 x 3.5 grey prop. Try APC, I think they make one.
Ployd
Ployd
