Everything Diesel Discuss R/C Diesel engines here.
What Do I Put This In?
Old 05-10-2008 | 10:56 AM
RocketRob's Avatar
Default What Do I Put This In?
Talk about Flash Gorden/Buzz Lightyear
But what kind of airplane will it look right in?
Or maybe the exhaust will create enough lift? No plane required....
Art Deco 50's??? What did they do with these in the 50's
Old 05-10-2008 | 12:38 PM
LeeHop's Avatar
Default RE: What Do I Put This In?
Great looking engine, Bob.
How about a [link=http://www.lanierrc.com/airplanes/lana1700.html]Lanier Shrike[/link]?
Old 05-10-2008 | 02:39 PM
digital_trucker's Avatar
What engine is that?
Old 05-10-2008 | 03:09 PM
Motorboy's Avatar
This is a Taifun Hurrikan, made in western Germany
Old 05-10-2008 | 03:13 PM
AMB
Bob you are the only guy on earth that could come with something like this, My guess the guy who did Caddilac tail fins did this as a crafts project while he was in the mental
institution, It would look pretty neat in some sort of a period racer (for real) however very unique martin
second idea build a canard no front flying surface would have to be made
wonder how much thrust the exhaust makes
GERMANY?? maybe one of the guys who designed V-2 rockets after the war got a new job
Old 05-10-2008 | 05:33 PM
I like Cadillac tail fins .....
Old 05-10-2008 | 05:37 PM
AMB
All kidding `It does have an aerodynamic design compared to the usual muffler and a dual too martin
Old 05-10-2008 | 08:14 PM
lildiesel's Avatar
How about this?
On a more serious note, I can't imagine using that on an airplane since it would be like adding canards to any design. I've always thought that the Jetsons muffler was intended for use on Hurrikans being used in boat models. This is the first time I've seen a that muffler actually on an engine, though. I saw it with it's box in a display case of German made model engines in the Modellflug section of the Deutsches Segelflugzeugmuseum at the top of the Wasserkupe in the Rhoen.
Old 05-11-2008 | 12:51 PM
As a kid in the late 50-ies, this Taifun was one of THE engines to buy along with Webras. Remember, that was the Control Line area, and everything that just looked pretty would have a high "wish to posess" value, though practical value of that exhaust was low. Probably due to piston sub-induction which caused spent gasses to re-enter the crankcase.
Glow engines was something that the Americans tampered with at the time, and eventually it caught on in Europe as well, even though these engines did not nearly lasted that well and were not able to pull a decent prop without loads of nitro.
Old 05-11-2008 | 09:55 PM
RocketRob's Avatar
I've been told they sortof went by the wayside when the Ollie Tigers came on the scene.
But then again it was a mass produced engine as compared to a "Special" from a cottage industry.
I'm additionally drawn to this engine because it could have been manufactured the same year as me[8D] 1958.
However it appears to have weathered the years better.
ID:	947760   Click image for larger version
Old 05-12-2008 | 03:36 AM
My Feedback: (10)
Why would you use a motor like that! It's pristine, and if you check out what it's worth in it's current condition you'd be half way to an Oliver!
They are only a reed valve induction motor of modest power. A nice 09 but not one to build a model for.
That motor with the genuine exhaust would make over $200 on the bay.
I'd look out for one of the Oliver repro cubs, a far better motor!
Cheers JG
Old 05-12-2008 | 06:47 AM
RocketRob's Avatar
I agree with you. I have not run this one while in my care. I have a runner with a used exhaust and another runner which is rc w/o exhaust. It is actually fairly strong in my estimation spinning a 7x6 prop between 12,600 and 12,800 and feels quite light.
Old 05-12-2008 | 09:05 AM
Sport_Pilot's Avatar
Great idea. You could hinge the motor mount and have vectored thrust as well as an all flying canard!
Old 05-12-2008 | 09:14 AM
LeeHop's Avatar
That really is a canard!
Old 05-12-2008 | 03:45 PM
ORIGINAL: RocketRob
The engine is great powerwise. Not the normal run of the mill power anyway but a lot more!. BTW: Not a reed valve, but a disk valve.
200 bucks won't make you rich. A nice engine in a nice plane certainly will! Treated well, this engine will last forever and a day.
Use modern racing two stroke all synthetic oil, 50 grade, instead of Castor (like Mobil1, Elf or Putoline MHX), and the engine will stay clean.
Old 05-12-2008 | 08:07 PM
My Feedback: (10)
ORIGINAL: pe reivers
ORIGINAL: RocketRob
Hi Pe
Hate to argue with you, but the Taifun Hurricanes are definitely reed induction engines! I have owned and run one, they are nice, they are light, they have excellent handling qualities but they are no power house.
And while $200 won't make anyone rich, it would be a shame to mess up such a pristine example especially when there are so many other good user engines out there and regardless of how careful you may be, an accident is just waiting to happen to those lovely mufflers.
Cheers John
Old 05-13-2008 | 07:35 AM
IIRC, the engine has a circular plate check valve, that is closed by a spring and by gas pressure. A reed valve closes by it's own flexibility, and always is fixedly connected to mass at one location. The two are alike, but different.
Old 05-13-2008 | 07:19 PM
RocketRob's Avatar
For what it's worth, the spare rear intake valve assembly, and a "Family Photo".
On the left, living within his oily bag is the one in previous photos, center the CL runner complete w/ faint plyer marks on cylinder , and on right the RC version runner which WILL go in some kind of plane - someday
Guess I have a Hurrikan thing
ID:	948896   Click image for larger version
Old 05-14-2008 | 08:53 AM
Nice pictures, Thanks. I must admit that's a reed valve for sure!
These engines seem in pristine condition.
