Tadpoles
1 Attachment(s)
Has anyone ever seen one of these?
Are they still available? A running report from an owner, not just a collector, would be most appreciated. |
RE: Tadpoles
Derek,
I haven't seen the Tadpoles, but Ian Russell (Rustler) is a regular contributor on Barton CL site. It would be worth asking him the question. I have one of his Olly Tiger replicas, an absolute gem of a motor. Regards Greg |
RE: Tadpoles
Yes-I have one (as you'd expect) and yes-its rather nice! Came with two tanks-one metal one plastic, and is a very accurate representation (on a smaller scale obviously) of the Frog 50 Mk1-and with a LOT better handling than the original. Quite pokey too-a lot better than the similar sized ED Baby 0.25cc replica-though the latter is a joy to run. So far mine is only bench run, and has yet to find itself a model home-but I'm leaning towards either the Ron Warring 'Titch' from ca 1953 or the Skyleada 'Point Five'..........
.......I'm just back from the flying field after a morning of mixed success trimming-pre Nats checking of some of the fleet-and in keeping with the forum, am pleased to report the Doonside Elfin 149 continues to start and run impeccably. The 'Midi Pearl' that it's in however, needs some minor fettling-a snid more left thrust, and a gnat's foreskin less right rudder to sort the climb out. On the plus side the first of two 'Y-Bars' had its maiden flight this morning, a mere 8 oz on a Cox Space Hopper-which also had its first run (at least of my ownership).....~=*!! reed valves..............flick it forwards-starts backwards, flick it backwards-still starts backwards..........required the starter to sort it out-but once running, took the Y-Bar skywards in the classical corkscrew pattern with no adjustments whatsoever required-a genuine 'flew off the bench' job. ....now give me a bit of time to have some luch, clean up etc-and I'll be back with some figures on the Tadpole.............. ChrisM 'ffkiwi' |
RE: Tadpoles
1 Attachment(s)
Well I've just run mine again on a Cox 6x3 yellow nylon. Still runs hot, and quite a lot of vibration. Its not a Mills 75 by any means in terms of starting-but at the same time-completely normal diesel responses-it's quite critical for optimum compression setting-and lets you know very quickly when even slightly over-compressed-by labouring quite markedly. Needle is not of the 'precision adjustment' variety (nor was the original Frog 50!)
Best revs at this stage on the 6x3 (which is the recommended running in prop) were 6700rpm on Model Technics D1000 homebrew. It could not run out a tank before overheating and stopping-so there is still plenty of running in to do-and Ian's recommended fuel mix (very high in castor) is clearly needed for this phase. [see scan of instructions attached]-I'll mix some of that up, and hopefully do a few more runs tomorrow. ChrisM 'ffkiwi' PS Even at 6700rpm there was plenty of thrust coming off the 6x3 Cox-certainly enough to fly a suitable small light model. |
RE: Tadpoles
Pretty impressive for a biggish fan, on a 1/4 cc engine. Thanks Chris.
RE: Tadpoles
Fiery-it's about 2 years since I last ran it-and it had a DC 5-1/4 x 3-1/2 prop on it when I dug it out today. I vaguely recall it was quite a bit faster-not surprisingly-but harder to start- on that one. I'll make up some fuel 'according to Rustler' and do some more running. I have quite a range of suitable props. I don't think I've run it on the Cox 6x3 before-and this prop is a heavier load than some others. A few more tests will establish what it's happiest on. My VA Bambi is very happy on the same 5-1/4x 3-1/2 prop (originally produced for the 0.75cc DC Bantam!) so it is not inconceivable that the little Frog with 2/3 more displacement might turn something a bit bigger with authority........
ChrisM 'ffkiwi' |
RE: Tadpoles
A nasty discovery made this evening-which may have a good outcome for the wee Tadpole down the track-the Cox yellow 6x3s are badly out of balance as moulded-I had vibration problems with two separate ones today-one on the 'Y-Bar' mentioned above and one on the Tadpole. Since I don't recall vibration previously being an issue with the wee thing when last run about 2 years ago, my nasty suspicious mind started thinking 'what's so different today?' ........and a check on the balancer revealed the problem. Not just a finger balancer-which is how I routinely balance them, but one of those good rolling wheel Dubro ones. The problem is mainly-but not totally-an out of balance hub, though one blade needed a bit of lightening as well. Fortunately I have a small supply of tungsten putty-which is ideal for balancing........
ChrisM 'ffkiwi' |
RE: Tadpoles
1 Attachment(s)
OK-one day later and I've just run it up several times on the now carefully balanced Cox 6x3-vibration is still present-so it may be a wee bit of a shaker. I have gained a few hundred rpm though-but whether this is due to the reduced vibration or simply a consequence or more running time is a moot point. 7000+ on a 6x3 would put it up there with the VA .4cc Mills and VA Kalper .32 for performance-so the little Tadpole is punching above its weight!
I haven't made up any of the specified fuel yet-will be interesting to see how that compares with my Model Technics D1000 mix. I'd expect the engine to perhaps sound happier-but produce less revs, on this mix (see previous post of scanned instruction sheet for the recommended fuel mix) Here's some pics-on a rather cool Wellington morning.......... |
RE: Tadpoles
Chris
I checked with Ian Russell (aka "Rustler Engines"). Unfortunately he no longer has any Tadpoles. They have all swum off. A pity. I would have bought one as a Xmas present to myself after reading those figures! I do have a current list of Rustler's available engines and spares. The list on Barton is very out of date. I am reluctant to post it up on this forum as it may breach RCU rules. I can email it to anyone who may be interested. If any reader wants a copy of the list, kindly PM me your email address. |
RE: Tadpoles
As we both know now to our cost-you have to get in quick with these little gems-whether they be Benno Schlosser's, Arne Hende's, Dave Banks'/VA or Ian Russell's ones-supply is strictly limited-and 5 or 10 years down the track you're kicking yourself for not getting one when you had the chance....
I've had the Tadpole since about 2000 I think-along with a 0.8cc Oliver Tiger Cub that also emanates from the same stable-judging by the style of the box artwork. more prop tests to follow..............now having a small plethora of checked and re-balanced props to play with............. On reflection I was probably unduly harsh on the starting properties yesterday(probably because it was a bit gummy and clogged up from previous runs 2 years ago)-while it certainly isn't a first flick starter, I didn't mean to imply that it was difficult to start. It responds well to finger choking (the suction is enormous-you can see the fuel level in the tank drop when you choke it), a couple of drops in the intake and a miniscule exhaust prime. ChrisM 'ffkiwi' |
RE: Tadpoles
Vintage diesels tend to vibrate. One way to reduce vibrations is to use out of ballance props with the heavy blade up when the piston is down. This has worked for me. I paint the heavy blade red so know which blade is heavy. Jack
RE: Tadpoles
deleted after edit
RE: Tadpoles
A carefully balanced prop has reduced vibration to a comfortable-as opposed to an unnoticeable-level in this case Jack. I think the deliberately unbalanced prop approach (I have tried it) works better on the larger long stroke vintage diesels with relatively heavy pistons. Then there is the simple and well recorded reality that some engines have 'vibration bands' corresponding to a few thousand rpm or so somewhere in their rpm range. Within this they vibrate badly-propped above or below this band they run smoothly. Then there is the utterly counter-intuitive observation that some engines where there is no attempt whatsoever at any form of counter balancing-and with heavy pistons to boot-run quite smoothly-I give you the ED Bee, Elfin 149, DC Spitfire and Sabre and the Frog 100/149/150s as examples. Go figure...........!
ChrisM 'ffkiwi' |
RE: Tadpoles
ORIGINAL: ffkiwi Then there is the utterly counter-intuitive observation that some engines where there is no attempt whatsoever at any form of counter balancing-and with heavy pistons to boot-run quite smoothly-I give you the ED Bee, Elfin 149, DC Spitfire and Sabre and the Frog 100/149/150s as examples. Go figure...........! ChrisM 'ffkiwi' The piston acceleration from rapid onset diesel ignition is resisted better with a heavy piston, a heavy full circle flywheel stores energy better between cycles and a solid block absorbs the vibrations. And the use of large prop, low revs and the old less powerful fuel mix of 33% of each helps too. But surely all of these old designs don't make 'that' much power in order to create the thump in the first place? So, if you'could' push any of the above engines to say 18 000 rpm and beyond, would they then start to vibrate badly? Would they then be really better off with proper counter balancing? |
RE: Tadpoles
Put a flywheel on one and see..........
CJM |
RE: Tadpoles
Some wheres in my parts bin is a "flywheel" the intended use was to add weight to balance the plane it replaces the front drive washer and front is recessed to get the prop nut on
and they are heavy can get in various weights 1 oz not uncommon might work to reduce vibration martin way too big for the wee ones at least an inch in diameter 1/4 inch bore maybe 35s and up |
RE: Tadpoles
Hi Chris,
I don't have any of the engines that you listed but I have run modern marine engines - they don't seem to mind flywheels (not sure what that proves though.) But I have an old PAW19 DS that had a full circle flywheel that used to vibrate quite badly and after grinding off the cheeks as an attempt to balance it, and it was much better. Do you think that adding a flywheel makes this better or worse? |
RE: Tadpoles
on the front flywheel thing it could be ground down on one side to unbalance you would have an external counter weight with getting it in proper position on shaft martin
RE: Tadpoles
(1) I meant put a flywheel on in place of a prop and run one at 18,000 plus..........and see what happens...........
(2) I'll bet your modern marine engines have very light pistons, massive blocks, and heavily counterbalanced crankshafts............ (3) Even people like Cox got it wrong from time to time-the TD15 and it's successors were notorious for vibration in their day when propped for peak revs-'shake timers to bits' was the expression used by some of my older mentors who did use them. The answer was to grind both flanks of the crankweb carefully to increase the degree of counterbalancing. The magic figure-according to the books, is balancing 60% of the reciprocating weight.......... (4) OS went to the extent of using counterbalanced prop drivers for a while in the 1960s on the Max-15 and 19-did it work? I don't know-they stopped doing it........ (5) Anyone remember the famous K&B 45 greenhead-arguably the first 'proper' pattern engine? It had a backplate mounted counterbalance driven from the crankshaft to improve smooth running (6) The russians-no fools when it comes to miniature IC engine design-even went as far as drilling holes axially around the circumference of part of the shaft to counterbalance the weight lost from the intake cutout.........and this was in a cheap F2D training motor.....the Typhoon. ....as for me, all I will say on the flywheel aspect is that I have several engines fitted with heavy brass spinner nuts for CG purposes-(and one is your beloved PAW19 DS!)-and these engines seem to start easier and run smoother than those without-but I've never systematically looked into it. ChrisM 'ffkiwi' |
RE: Tadpoles
Chris I 2nd your observation on the heavy brass spinner nuts and noticed the same thing easier hand flipping to start and reduced vibration martin
think that heavy spinner gives you inertia on the flips |
RE: Tadpoles
I think you're quite right Martin-but there must be a point somewhere where the excess weight starts to slow the engine. I suppose if one was anal, had a lathe, plenty of brass and a lot of spare time, one could machine up a whole raft of heavy spinners, in increments of say half an ounce difference, and then, with all other elements-fuel, prop, temp, etc constant, run a series of tests..........
ChrisM 'ffkiwi' |
RE: Tadpoles
1 Attachment(s)
I will also say the same.
I put a Harry Higley brass "heavy hub" on a .46 powered pattern trainer for CG purposes. I hid it under a 2 3/4 " diameter spinner. Increased smoothness and reliability of the engine at idle was noticeable. I noticed no difference in throttle response. Hand starting was a snap. Some old hands predicted dire consequences would follow. Warnings of "increased gyroscopic precession", stressing the front ball race beyond its rating. I never noticed any issue. Engine was fine. |
RE: Tadpoles
The issue that I have with adding weight and therefore inertia to the non driven end of any crankshaft is increasing the possibilty of a spiral fracture.
I have seen a few of these in front induction diesel conversions and they radiate from rear corner of the intake cut away in the crank and progress towards the crank web twisting around in a 45 º spiral. Personally, I think that the weight is being added to the wrong end of the shaft - but if the shaft is strong enough ................ |
RE: Tadpoles
It's a bit difficult adding a flywheel internally.............
CJM |
RE: Tadpoles
Drill out the counter weight and add in tungsten rod seems to be the ultimate.
RE: Tadpoles
What is that great looking aircraft? Is it a kit,plans or arf
RE: Tadpoles
A lowly VMAR "Arrow Tiger" ARF pattern trainer.
55" span. Symmetrical airfoil. Shape reminds me of 'half-half' P-51D Mustang and Bf 109-G Messerschmitt. Still available. http://www.levelflight.com.au This business also sells ENYA 2 and 4 stroke diesels. A big plus from me for that. I have just bought a VMAR Scottish Aviation "Bulldog" for an Easter 2013 Build, to be powered by a diesel 10 cc. Build and wood quality is much improved. It's no 'World Models' ARF, but excellent value for the price. Apologies ... I am a long way off Micro-diesels. |
RE: Tadpoles
1 Attachment(s)
Fiery have several VMARs the Apache ll and lll among them the apache ll has been around a long time sturdy build had an Irvine 40 diesel then a upgrade to Irvine 53 Davis head
on the 53 it will knife edge also the hot rod high wing the apache lll has a side mounted 52 4strk ASP and cowled in to get a way from the trainer look also a low wing arrow 40 size think it is a VMAR and an other high wing Hot Rod I have no beefs with VMAR qualitythey had some issues years ago but no more, at least in the last 10 years martin Post Note I do have an ASP/MAG 4 strk converted to Diesel by Greg Glamryz that I can swap in |
RE: Tadpoles
But I'm OT!..............10,050rpm on a Cox 5x3 yellow this morning-unfortunately the camera batteries went flat when I tried to get the tacho shot........more to come. The Cox 5x3 still represents a significant load compared to other 5" props such as the Topflite or DC 5-1/4x3-1/2, so the performance continues to impress. Engine sounded very happy running this prop-but definitely harder to start.
ChrisM 'ffkiwi' |
RE: Tadpoles
Over 10,000 RPM on a Cox 5 x 3?
Now I really want one! I have a box of those Topflite 5 1/4 x 3 wood props too ... As you said Chris, lesson learned. |
RE: Tadpoles
It took a bit of tweaking to get it there, but we made it in the end. Camera batteries currently on charge, so I'll try and get a repeat run later-but its getting warm here today and it may not be so happy-we'll see.
Eventually I will run it on the raft of small props I've carefully balanced and we'll have some reasonable figures for reference. I won't do the APC ones though-as they'll need a bushing machined up, and I'm too busy with my Nats preparations. Perhaps early in the New Year, after I've returned from down south. ChrisM 'ffkiwi' |
RE: Tadpoles
sounds like the tadpole turned into a bulldog martin
RE: Tadpoles
Well how much you'll eventually see once I run a series of comparative tests of the same props on the mini ED Baby of the same size..........but I need to make a compression screw lock for that one
CJM |
RE: Tadpoles
1 Attachment(s)
'ere we are then-10080rpm, proof positive............
CJM .....a quick check on the calculator suggests that this equates to ~0.013 BHP.......there may be a bit more to be got from the engine yet |
RE: Tadpoles
Chris
Is it able to drain it's tank yet on a given needle setting? Or leaning out and quitting? Now the Schlosser .25 cc's are also historical artifacts. it looks like I will have to keep my eyes open to see if one comes up on *bay. |
RE: Tadpoles
It still gets hot and labours to a stop unless you back off comp and richen the needle after about 1-1/2 minutes running-I've probably managed to run the tank dry twice in about a dozen separate runs. The shaft is a beautifully free fit in the main bearing so I'm assuming its cylinder friction is the issue here. I also noted today that the contra seems to freeze after more than a couple of minutes running [for the run where I took the photo, I topped the tank back up from nearly empty whilst it was still running-so that was a longer run than usual-and found that I couldn't back off the comp once the engine started to labour.
One thing I'll say for the wee beastie-you can tell whens it's happy.........and you can definitely clearly hear when it's unhappy........ ChrisM 'ffkiwi' |
RE: Tadpoles
It has a nice tight P/L fit - check. It has a contra that 'locks up" when really hot - check. These are plus points. I dislike engines that are a "loose" piston fit out of the box, and diesels with leaky contras are annoying. The issues will only improve with running time, which is a bonus with a diesel this small. |
3 Attachment(s)
G'day Derek, Seeing that run today was sensational, well done
Nice nail polish BTW (VVTIC) Cheers Mate |
