RCU Forums
-   Everything Diesel (https://www.rcuniverse.com/forum/everything-diesel-87/)
-   -   more conversion heads.. (https://www.rcuniverse.com/forum/everything-diesel-87/1418734-more-conversion-heads.html)
ajcoholic 01-10-2004 05:27 PM
1 Attachment(s)
I made today, a diesel head for an MDS 1.48, and one for an ASP/OS .91 FX.
They are just awaiting the viton I O-rings (should be in Monday or Tuesday).
As usuall, made from 6061-T6, finish is a combination of glass bead blasting for the matte and as-machined for the shiny. I have a small setscrew and brass insert to hold the contra adjustment screw.
Tried my new slitting saw out today,its coarser and cuts much better in aluminum without clogging like my old one.
These were made for two of the regulars here.. :) Hope you guys like em' and they work out. Should be able to ship as soon as the O rings get here and I will include a few spares as I had to buy a 10 pack.
AJC
Hobbsy 01-10-2004 05:54 PM
RE: more conversion heads..
Well done AJ, they look beautiful, now it's like waiting for Christmas again.
maxtenet 01-10-2004 06:04 PM
Looks good AJ!
I haven't had time to do much machining lately. I just got the castings for the HP .40 Grand Prix (never produced) from Randy Linsalato at MECOA. Long history as OPS bought out HP and then MECOA bought HP from OPS. OPS made a very few and called them the Monza .40 (one of which I have) and then sold the castings. Let me know if you guys want pictures as the castings are beautiful! Also just got castings for a ZALP .15 which is very cool. I'm a (was) long time IC subscriber and now have no other sources for info now that they folded. I'm wondering if we should start another category which is related to machining or homebuilding engines? How about some feedback on this!
Max
ajcoholic 01-10-2004 07:12 PM
Max - What do you do with castings, when you havent any drawings (unless you also have them for the HP, I assumed not)? Make up your own design I suppose? I think there are enough guys here that are into machining engine parts or complete engines to have some sort of forum, but its also fine for me to have it within forums I allready post in too.
I tell you, the idea of a 1 and a half cubic inch model diesel is pretty awesome... I wish I could be there when you run it up HObbsy! What prop are you going to use?
AJC
Hobbsy 01-10-2004 10:18 PM
I normally load a Diesel conversion about 30% over the glow load, so in this case I'll start out with an 18x6 three blade, it should turn it in the high nines. The engine is going on a H9 UltraStik Lite. I have two of the early C1 MDS carbs that work very well, the C2 carbs are 10mm these are a wee bit under 9mm.
AMB 01-10-2004 10:19 PM
WOW WOW it is Christmas again looks great can hardly wait-- Looks like a head that
will fit my ASP 91. Hobbsy you better have AJ scout up a Canadian maple tree that
can be milled into a prop,The h**l with the prop what are you putting this in maybe
an airboat to take you fishing?? Also the pics I am sure do not do justice to great
machining. After looking at these I suspect a few of the lookers may have a drool attack
AMB 01-10-2004 10:34 PM
Hobbsy in a serious note what is the wingspan of the stick?? .you will have to
have some-one video this in the spring should be awsome
Hobbsy 01-10-2004 10:44 PM
75 inches and hopefully under 10 lbs.
AMB 01-10-2004 11:02 PM
Hobbsy i guess a smooth exit from a hover will not be an issue.
AMB 01-10-2004 11:05 PM
and only 14.8 x the displacement of my OS conversion in my cub
AMB 01-10-2004 11:10 PM
Ok I guess its time to put the diesel head on my 0.020 cox
Hobbsy 01-10-2004 11:13 PM
It's only 5 degrees here right now and I'm sure it's much colder where AJ is, I can't even think about running an engine.
AMB 01-10-2004 11:45 PM
Hobbsy 35 here in fl winds NW 20=25 will hit 60 or so this afternoon but unless
wind drops not a fly day right now 4mph gusts to 23 I cant even imagine what its
in AJs town
AMB 01-10-2004 11:58 PM
If no go on fly sunday will start the 2nd vmar cub (like the first one)
and will put in either the enya 11d or TT10 conversion. again for the electric field
ajcoholic 01-11-2004 11:26 AM
Yesterday and the day before, it was into the -50's when I went to work. Today it warmed up to -20 C (about 3 or 4 F I think for you US boys :) )
I just got back from walking the dog, and shovelling the driveway. Not going flying today..... building in the warm shop sounds a lot better!
Jan and Feb is very cold here usually, but come mid MArch I start thinking about flying again..
AJC
Hobbsy 01-23-2004 06:47 PM
The new head arrived today and is every bit as beautiful as Andrew's pics indicate. While I was waiting for the head I replaced the sleeve and piston in the 1.48, the ring was rusty as was the rear bearing. It appears the original owner used all synthetic. So, now that I have the old head back I can braek in the new cylinder and piston. The new head fits perfectly and looks good on the engine. As an interesting aside the new cylinder is perfectly smooth inside, no crosshatch and holds compression like a properly broken in engine when rotated by the prop driver. Excellent job Andrew.
ajcoholic 01-23-2004 09:12 PM
Cool! Lets here how it runs! :D
AJC
AMB 01-23-2004 09:22 PM
BO HO mine has not got here yet for the ASP 91 maybe saturday mail service to florida bad as
Canada the whole country gets stuff before Florida
Francis your 61 mvvs head being mailed Sat AM priorty mail
waiting also for the LA 15 head from Paul at JE
AJ maybe I can twist your arm to make me a head for my irvine 40 glow it is not the same
as the irvine 40 diesel/ Q40 head bore a little different )this would be an anytime you have time
thing
Now guys hows that?? all this in one post martin
ajcoholic 01-23-2004 09:24 PM
SUre, just send me the head and I will fix you up... :)
AJC
AMB 01-23-2004 09:31 PM
AJ will pull the head and get it up (as a matter of fact tomorrow when I send francis the
now extra mmvs 61 diesel (factory head)
AMB 01-23-2004 09:35 PM
Talk about our group diesel dementia Francis called be last night about the head I guess
via dave and he is or has run out to get an MVVS 61 to put under it ( he is really getting a deal
on it)
AMB 01-24-2004 12:01 PM
Francis your head left today priority mail insured from goldenrod FL martin
my guess Tues or Wed delivery
Hobbsy 01-29-2004 11:30 PM
We could sure use some good weather here, I want to try out my new head, I'm tired of wearing it out looking at it. I want to put a little time on the 1.48 before I Dieselize it. I know AJ can't help me with the weather but Martin can. So send some warmth this way please.
ajcoholic 01-30-2004 07:13 AM
You certainly dont want what I have to offer in the weather department! :)
(Brrrrrrr......)
AJC
AMB 01-30-2004 07:24 AM
Hobbsy you need a orange grove heater looks like a giant bernzomatic torch** use them in the
orange groves to prevent frost damage one of the groves near here had them plus (get this)
a aircaft engine (maybe a airboat set up blowing the warm air over the trees) on tower about 20 ft up (This is not a joke for real) A very large space heater** is a better description with a stack
on the top this has to be the worlds largest oscilating fan ( no doubt one of AJs projects when he
visited Florida)
