RCU Forums
-   Everything Diesel (https://www.rcuniverse.com/forum/everything-diesel-87/)
-   -   Diesel conversions using existing head (https://www.rcuniverse.com/forum/everything-diesel-87/1732097-diesel-conversions-using-existing-head.html)
Kimhoff 04-17-2004 10:34 AM
Does anyone know anything about these gadgets that you screw into the exisiting cylinder head in place of the glow plug to convert to diesel? Do they work? Where can a person get one of these?
Motorboy 04-17-2004 02:43 PM
RE: Diesel conversions using existing head
ORIGINAL: Kimhoff
There are not some parts to screw into exiting cylinderhead and run as diesel. 4 stroke engine only.. I has Magnum 52 4 stroke with combustion camber w/ contrapiston screwed in plughole. For 2 stroke engine go to webside: http://www.davisdieseldevelopment.com/
Jens Eirik
Jim Thomerson 04-17-2004 10:35 PM
I think I have heard mention of such a device. I've run a regular glowplug K&B 4011 on Davis 1/2A diesel fuel and it ran fine. I had to leave the glow plug battery on for about 30 seconds until it warmed up so it would run steady.
Jim
Hobbsy 04-18-2004 08:30 AM
There is indeed such a gadget, of all things called the Gadget, it is mfg. and sold by a man in LongIsland by the name of Lou Furco. RedMax has the fuel for it.
Kimhoff 04-18-2004 09:27 PM
Does Lou have a website?
Hobbsy 04-18-2004 10:54 PM
Kent, he only has a phone, 631-884-3266
Kimhoff 04-19-2004 10:06 PM
Anybody used one of these Gadgets?
maxtenet 04-22-2004 03:52 PM
Yes, and they are a glow plug drilled out and fitted with a copper plug. The idea behind them is to let someone explore running their engine on diesel to see if they like the whole diesel concept without spending a lot of money. While they run, they do not run at optimum setting as they are non-adjustable and every engine is different. As an experiment, they are fun, but for practical use (like flying an airplane) they are not worth a crap.
Max
