Calculating compression ratio
Hi,
I'm wondering. Isnt it so that the compression ratio of a engine is : the volume of gas in cilinder at DBP(lowest, all ports are "just"closed)), compared to volume of cilinder at TBP (top) ? Im trying to calculate the compression ratio of an OS 46FX (Glow, not diesel yet)) , but I'm already lost. Bore*stroke should be 7.5 cc according specs, but thats not the case. Hope someone can help me out. Best regards, Frank |
RE: Calculating compression ratio
Hi, you can calculate totalvolum of stroke (not all ports are "just"closed, allways from BDC to TDC) and bore and measure volume of combustion volume in cylinderhead (use syringe with sewingmachine oil to measure volume with piston at TDC and fill oil until plughole).
The formula are: Totalvolume of cylinder + combustion volume : combustion volume = Compresion ratio Jens Eirik |
Engines have a mechanical compression ratio measured using the total bore and stroke and an effective or "corrected" compression calculated from when both valves are closed on a fourstroke and from where the exhaust port is closed on a twostroke. You would amazed at how far up on the compression stroke the piston is on a Saito before the intake valve closes.
I was wondering about the possible corrected compression ratio too, those gasses run into the cilinder pre-compressed so to speak. Calculated and technically the stoke*bore on this .46 is 7.5 cc. If I move up the piston untill the last port closes (outlet) I only have a 5.7 cc left in the cilindre . At TDC there's only 0.4 cc left so that means I have a compression ratio of 1:14. What volume to take, the 5.7 or 7.5 CC ? Id want to calculate the volume I need to make my conpression "room" adjustable from 1:16 to 1:20 Regards, Frank |
1 Attachment(s)
"Compression ratio" has nothing with valves/ports when they are closed, it is wrong to calculate compresion ratio.
See at the picture from "Model Aero Engine Encyclopaedia" 1969..;) Jens Eirik |
Jens,
Thanks for taking the effort to convince me :) I'll stick to Bore*Stroke. Best regards, Frank |
The effective compression is the one that dermines the way your engine runs, the mechanical compression ratio is what it would be if it were a closed cylinder without ports or valves that are open for part of the stroke. So the effective or corrected compression ratio is the one that matters in the real world.
1 Attachment(s)
knarf, here is an alternative to your question about the .46 sized conversions, an OS LA .46 with a Davis Conversion Head. I'll copy and paste what I had to say about it when I first got it.
I converted the LA .46 with a Davis Diesel head today and the results are great, Davis, Oily Mix/ Plane fuel MasterAirscrew 12x6 three blade 8,800 rock steady, does not wander, still working on the idle 2,500 so far. I'm flying it tomorrow. Throttle up is clean and crisp. I could squeeze about 9,000 rpm out of it but it wanted to hunt between about 8,900 and about 9,050, I reduced the compression slightly and it settled into 8,800 as mentioned above. This was on Davis Oily mix or Plane fuel as he calls it. |
hobbsy,
Your numbers are quite impressive. Have fun tomorrow. I already ordered one head too for my magnum XL .46A. Still like to do some diy conversions I have a lathe, i guess i should use it ;) |
I'm confused. I own a book called 'Modellmotoren" by Peter Demuth (1989) in which is stated that you have to calculate the compression from the point where the exhaust port is closed:
http://www.modelbouwforum.net/~foto/...s/afb12459.jpg http://www.modelbouwforum.net/~foto/...s/afb12460.jpg Another question: when designing a diesel-head, do you take into consideration the clearance between the piston at TDC and the head? (squish band) In my case this is 0.5mm (0.02 inch), which in my opinion, should have a considerable effect on compression ratio. |
Micro, he is correct, no compression happens until all the ports are closed. Check my post #7.
1 Attachment(s)
Here is look at the difference between the Davis Diesel head on the left and the stock head on the right for a SuperTigre 4500, the piston comes even with the top of the cylinder with out the gasket. As you can see in picture #2, counting from left to right, the squish band clearance is about 4 times as great in the Davis head as in the stock head. I suspect this was done to give the contra-piston a greater effective range by softening its effect near the bottom of its travel, I don't think its effect on the compression pressure is linear.
ORIGINAL: hobbsy Micro, he is correct, no compression happens until all the ports are closed. Check my post #7. http://archive.dstc.edu.au/BDU/staff...ndex.html#qa13 In my early post #5 are geometrical compression ratio... Jens Eirik |
I have the strong suspicion that indeed compressions ratio is calculated from the point of all ports closed.
My self converted OS10FP (with 2 piece contra :) ) and .46 OS run fine at approx 1:19 / 1:20 CR. (calculated from all ports closed, it must be the fuel i guess ) If I would calculate the CR from pure bore*stroke for both engine i would end up with a CR of approx 1:14/ 1:15. My mix is 54/33/15/2 or so (I have hard time remembering numbers lately :) ) Best regards, Knarf. |
the squish band clearance is about 4 times as great in the Davis head as in the stock head. I suspect this was done to give the contra-piston a greater effective range by softening its effect near the bottom of its travel, I don't think its effect on the compression pressure is linear. So it looks as if increasing the squish band decreases the amount the compression can be varied, but on the other side makes it possible to set the compression more precise. Concerning the right way to calculate compression, I made sure that my contra has enough travel to set the compression between 1 : 14 and 1 : 20, regardless of what way it is measured. That way, if the head itself works, it should be possible to set the compression correctly. |
I don't think the actual compression ratio of our Diesels is anywhere near the 16 - 20 to 1 that we calculate using the bore and stroke. I have tried to run Davis Diesel fuel in my Saito .80 which has a 14.4 to 1 compression ration and I can't open the throttle past halfway because it has too much compression. It starts on one one flip using a glow plug with no element in it.
ORIGINAL: torque wrench I don't think the actual compression ratio of our Diesels is anywhere near the 16 - 20 to 1 that we calculate using the bore and stroke. I have tried to run Davis Diesel fuel in my Saito .80 which has a 14.4 to 1 compression ration and I can't open the throttle past halfway because it has too much compression. It starts on one one flip using a glow plug with no element in it. Anyone tried that? |
This is an interesting fuel mix option, how long does it take to warm up? When you are starting are do you only need to prime the engine with the standard diesel mix? If so how much prime is needed? Are you using a starter to get it kicked off and do you need to change the compression to start?
One other thought is you might consider adding say 5 - 10% cheap starter fluid (i.e Thrush $1.99 at WalMat) and see if you get any change easyer starting or more (or less) power, would be great if you could give prop & RPM info. |
Charcoal lighter fliud is usually petroleum naptha and some additives. Coleman fuel would be similar. Naptha refers to a wide range of fuel petroluem distillates. Coleman fuel is mostly naptha. It's not all that different than kerosene. I might have to give this a try.
Greg |
| All times are GMT -8. The time now is 03:39 AM. |
