Go Back  RCU Forums > RC Helicopters > Exceed RC Support - Helicopter
 Coupons & Stuff about an Eagle 50 >
Exceed RC Support - Helicopter Discuss all Helicopter Support for items purchased or will be purchasing at Exceed RC.
Old 01-20-2008 | 09:19 PM
AZheli's Avatar
Default Coupons & Stuff about an Eagle 50
Had a surging problem with my Eagle 50 tail motor (I thought). Was afraid it may have been a transmitter/controller problem, so I ran the tail motor directly from a separate power source. I also ran the main motor separately & found IT would increase/decrease rpms, even though the voltage was constant. Apparently there was enough current drain fluctuation from the main motor, that it had a more noticeable affect on the smaller the tail motor.
Nevertheless, I took it all out to the park down the street & promptly drove it into the ground - hard enough to trash the rotors & break the anti-crash set-up I made from some bamboo skewers & ping-pong balls - works great on smooth floors, but snagged on the grass & flipped the heli, causing the partial demolition.
The main motor quit surging - it bit the dust & the 2 pieces of the swash plate that are normally snapped together now keep coming apart.
Does anyone know how the top piece of the swash plate is fastened into the bearing of the bottom piece? Are they glued? They don't appear to want to snap together.
After totaling up the cost of all spares I wanted to have on hand, I found it cheaper to just buy a 2nd eagle 50 to use as parts - plus I get a spare LiPo battery that is otherwise out of stock.
Now the good part: *** coupon# cjfree2 *** will get you free shipping, so go order all the heavy stuff you want & use the free shipping code.
Old 01-21-2008 | 02:26 PM
Default RE: Coupons & Stuff about an Eagle 50
Surging... couldn't honestly say what... but I have noticed that just recently on the tail motor..
I have a third hand vice... that I mount the heli on.... it is set up that I can put the heli
on and able to test the control tabs on the TX such that the heli can spin around and trim etc....
and I have notice such a surge on the tail motor... but my tail motor right now is not stock
ie after market Walkera replacement... see my post..
http://www.rcuniverse.com/forum/m_6899234/tm.htm
You might at some time get such a device and mount the helicopter to it upon a "Lazy Susan" turn table...
it's great to test the tail motor and how and when you increase throttle the tail and the gyro
work together.
You will see... unfortunately... that they don't always work together consistently.
We are talking "cheap" electronics... as compared to $600+ helicopters Tx and Rx's.
I don't know if the surging is from RF interference or what...
maybe rattling around the gyro in the Rx is causing it...
But I was in the backyard working on my hovering and all seemed ok today.
It's between 10'f and 20'f... and windy... so I am just working on low hovering and control...
Swashplate coming apart.
Once it comes apart it will continue to do so...
I have found a fix in that I put tissue paper in the hole in the lower part
and push it together.. and that will hold it for a while.
It is a press fit... and thusly you can push it together again... I have a lot of times.
Next fix idea, that I haven't done is using the epoxy that is in a roll that you cut off
a section and mix it together in your fingers.... and shoving the epoxy into the
the underside hole in the swashplate so that it can't expand and come apart.
That is... you have two parts to the swashplate that come apart...
The lower with the bearing and the upper with the plastic press fit that goes into the lower.
Once the two pieces are connected... you would flip the swashplate upside down... and
shove the epoxy into the "hole" of the upper piece.. so that it can not expand and separate
from the lower piece.
Obviously being careful not to get epoxy stick mix you are using on any of the bearings parts.
And then of course is the next best option...
And that is learning how to fly and not crash all the time.
But I'm the last one to preach to that... ask my parts supplier... they just
bought a Porche from all my "donations."
