Flight SIM compatible with WK 0701
HI
does anyone know of a downloadable flight sim that the WK0701 will work on.. I bought a adapter to connect serial to USB originally came as PS2 to serial.. My computer lists the TX under com6.. I tried HeliSim, FMS, RealFight and those don't work with my TX.. With FMS i tried calibrating it and without any stick inputs the calibrating bars flicker...
Tanx..
Tanx..
HI
With FMS i tried calibrating it and without any stick inputs the calibrating bars flicker; then I unplug the cabe from tx, flickering stops.. Same goes with the other sims from Realflight and Clearview.
MD
HI
tanx.. tried that also, and same problem, while calibrating all bars flicker, tried the remedy posted and nothing.. Its probably my Tx trainer port is screwed up guess I'll just have to buy a trainer TX..
Thanx again
Thanx again
