Main Rotor Issue
Main Rotor Issue
Can someone give me a clue?
I flew my Eagle 50 for a minute it ended up side down on the ground. Nothing broke that i could see. Now when i try to fly it the main blades don't speed up enough to take off. I noticed the motor was going faster than the blades. I beleive the gear is spinning on the shaft. I tried tightening the set screw but it will not fix the issue. Do i need to replace the shaft? Could there be any other things i can check?
RE: Main Rotor Issue
i sugesst you remove the main gear from the main shaft. You can see the main shaft has a groove and the hex nut on the main gear needs to be locked to that groove.
Let me know
Andy
Let me know
Andy
Yep, had that problem - easy fix. What Andy was really saying is that there is a flat on the lower end of the main rotor shaft that the main gear set screw tightens down onto.
I found that if you don't get it tightened down onto the flat, it spins up, loosens & gives the symptoms you have. I got one of mine grooved a little, so had to disassemble it & spin it in a power drill & touch it up with some fine abrasive cloth so that it would properly aligh & lock down - no further problems with it.
The entire incident made me realize just how close the top surface of the battery is to the bottom of the gear hub/shaft end. I got nervous with the close proximity & cut & attached a piece of polypropylene margarine dish lid to the battery so the whole thing will gouge & scrape on it instead of on the battery, in case of a mishap. Poly pro is pretty tough & abrasion resistant & the small piece the dimensions of the top of the battery weighs practically nothing.
OR
Its important that from the main gear up the shaft to the T-hub you have no slop. This should all spin together as a solid unit.
PA
I'm very new to this. Both the helicopters and posting. You would think a retired Network engineer would be an old hand, anyway; I have a G2 which I am attempting to upgrade to aluminum parts. I can't seem to get the main shaft ( I believe It's called theprincipal axis), out of the helicopter. I can pull it all the way to the gears, then it gets stuck. Am I missing something... I read the post on the set screws, but I removed them
PA
Andy, I don't follow your comment on the main shaft and aluminum being different, Actually Mine were identical, only made of a different material.
The issue ended up being the flat spot mentioned earlier on the base of the main shaft. I believe there was enough of a bur, grabbing as I was attempting to pull it out. The new parts went in very nicely. After sitting here for hours, reading through all the inputs, I've gained a world of knowledge; However, I just wish it was more centrally compiled. Anyway, Thanks so much for the help.
