Exceed infinitive ep screw replacement
I accidently broke my steering hub part 02014 and lost a screw that holds it. I cant figure out which screw size i need can anybody give a suggestion?
CA
RE: Exceed infinitive ep screw replacement
The item number for the screw that holds the hub to the carrier is 02081, we don't have the screw in stock at the moment but if you Google "02081 screw" you'll find another online retailer that does have it at the moment.
-Charlie
CA
`I believe the screw threads into the hub, you can try putting a very small drop of CA glue on the threads before screwing it in. Make sure to not put that much or else the parts might get stuck together.
-Charlie
CA
http://www.nitrorcx.com/51c00-02081.html threads into http://www.nitrorcx.com/51c00-02014.html, there should be no room for you to use a locknut on the hub. Are we talking about the same part?
-Charlie
