Exceed RC 1/7 Scale SUPER 7 EP Electric Powered MadBeast Monster Truck Ready to Run w
https://www.nitrorcx.com/03c60-madbe...d-rtr-24g.html
The new Super7 MadBeast is Exceed RC’s newest monster truck and it is bigger and badder than ever. The new Super7 continues the lineage of the MadBeast line of trucks. A line known for its superb durability, reliability, and outright monsterous power. This new variation comes fully equipped with a revamped brushless powertrain and an improved chassis and suspension design. This new rugged design features improved performance and durability to maximized raw bashing power. The Super 7 is here and lives true to the saying "bigger is always better".
The new MadBeast EP features a rugged 540L brushless motor rated at 2400kv and a 100-amp XeRun programmable waterproof ESC. This new motor is shielded by an huge heat sink to safely allow maximum torque potential. This massive monster truck is powered by dual 7.4v 3300mAh LiPo batteries wired in series to generate a peak 14.8v of power. The MadBeast is equipped with anodized aluminum chassis plates and roll bar giving this 1/7 scale monster a super strong frame. Dual aluminum shocks with threaded collars and oil filled can be found on all 4 corners of the MadBeast EP to ensure that no terrain is too rough for this beast of a truck. The new slipper clutch design implemented on this truck protects the gears from the abuse of rough jumping and throttle smashing. The spur gear is heat treated aluminum to take a beating from high voltage power. This awesome new platform rides on huge wheels and custom low profile tires with extreme all-terrain tread. This wheel and tire combination gives the best of both worlds. High ground clearance and performance handling is the name of the game. The MadBeast Super7 is fully-loaded with upgrades to handle anything you can throw at it and is sure to be the king of the electric monster truck class.
Features:
2 Channel 2.4ghz Exceed RC Radio System
540L (36x65mm) 2400kv Sensorless Brushless Motor
XeRun 100A-R Programmable ESC 2-4S LiPo 3A @ 5.75v
ND1013 Metal Geared Steering Servo
Two 3mm thick aluminum chassis plate
8 Aluminum body shocks w/ adjustable threaded collars
Aluminum steering hub
Hardened & Coated Steel Gears
Multi-piece Anti-Sway Bars
Fully Sealed Ball Bearing Set
Robust Slipper Clutch Assembly
Two 7.4v Li-Po 3300mah 30C batteries included
Pistol 2.4Ghz Remote Control Radio
Specifications:
Type: Monster Truck
Scale: 1/7
Width: 18.1 in (460 mm)
Height: 12.2in (310 mm)
Wheelbase: 18.7 in (475 mm)
Length: 25.6 in (650 mm)
Weight (w/o electronic): 15.87lb (7.2kg)
Weight (with electronic): 17.86lb (8.1kg)
Chassis: 6061 Aluminum(3mm)
Drivetrain: 4WD
Gear ratio: 19.37
Motor: 2400KV Non-Sensored Brushless 540L (size 3674, 5mm motor shaft)
Steering Servo: 15kg
Speed Control: Hobbywing Brushless 100A
Battery: 4S 14.8V 3300mAh 30C Lipo
Tire Size: 6.7x3.1 in (170x79mm)
Wheel Size: 4.9x3.1 in (124x79mm)
Wheel Hub: 17 mm
Radio: 2.4Ghz
Ball Bearings: Complete
Shock Type: 12mm Diameter Aluminum, Oil Filled
Is Assembly Required: No
Speed (Approximately): >36mph (58 km/h) with 14T pinion gear
Eletronic Waterproof: Yes
This item Does NOT come with Charger.
Features:
Specifications:
Type: Monster Truck
Scale: 1/7
Drivetrain: 4WD
Gear ratio: 19.37
Wheel Hub: 17 mm
Radio: 2.4Ghz
