Exceed RC 1/16 2.4Ghz Sava Blue Magnet EP Electric RTR Off Road RC Truck
https://www.nitrorcx.com/51c853-savablue-24-ghz.html
2.4Ghz Exceed-RC Magnet 1/16th Scale Electric RTR Remote Control Off-Road Mini Monster Truck Series
The new 2.4Ghz Exceed-RC Magnet 1/16TH Scale mini monster truck is a top performer. This is not a toy , it's a high powered RC electric Mini Monster truck and is very Fast and Durable. You won't believe the speed of this mini truck. The new Exceed-RC Magnet 1/16TH Scale has good looks - More power, more control and more Street Respect!. Complete with a powerful 380 motor, High capacity 1100 MAH Battery and electronic speed controller. This RC Truck will reach amazing speeds. Everything you need is included with this RC Truck. It is pre-assembled with all RC equipment fully installed.
Feature:
High quality double shock absorbers provide wonderful shock protection.
Powerful high precision RC-380 motor and ESC (Electronic Speed Control)
High performance 7.2V 1100mAH battery pack would never fail to power these 1/16th scale EP vehicles quickly.
High precision electronic speed control serves on these 1/16th scale EP vehicles.
2.4Ghz 3 Channel Receiver provide extra range for any remote control cars.
Durable And Anti-skid Wheel Tires with metal dog bones that with stand any hard hits and high performance double shocks on each end of the mini truck.
New lightweight suspension arms deliver quick suspension response and reduce the critical sprung weight and overall weight of the truck
Specification:
Feature:
- Four wheel drive system with shaft drive
- Can run on any road surface
- Powerful high precision RC-380 motor and ESC (Electronic Speed Control)
- Equipped with high speed motor and bevel gear differential gear box
- Pre-mounted buggy wheels with durable aggressive thread tires provide high performance in off-road racing
- Transmission shaft enables the car steadier, light shock & fast speed while running
- Extra large radio tray provides stable rest for servo and radio system
- High capacity 7.2V NiMH rechargeable battery
- Front /rear bumper provide good protection against accident impacts
- Equipped with axletrees to reduce friction of the components and to run smoother and faster
- Front and rear double wishbone suspension
- Double Coil spring shock units
- Double wishbone arms with adjustable width
- Oil filled aluminum capped shocks
- Oil serviceable gears built-in high quality bulkhead
- Professional front steering system features quick turning response to whole vehicle
- Top quality chassis
- Complete Kit, Ready to Run (Everything is included and 100% assembled
Specification:
- Length: 251mm (9.88 inch)
- Width: 216mm (8.50 inch)
- Height: 120mm (4.72 inch)
- Wheelbase: 174mm (6.9 inch)
- Ground Clearance: 18mm (0.7 inch)
- Gear Ratio: 1:11.1
- Wheel Diameter: 69mm (2.7 inch)
- Wheel Width (Front): 29mm (1.1 inch)
- Wheel Width (Rear): 29mm (1.1 inch)
- Engine: RC-380 motor
- Battery: 7.2V 1100mAH Ni-MH
- Truck (100% assembled)
- 7.2V 1100mAh Ni-MH Rechargeable Battery
- Wall Battery Charger
- 2.4Ghz Pistol Grip Radio Remote Controller with Antenna
- Instruction Manual
