Tacon 1/14 2.4ghz Green Soar Brushed Ready to Run RC Buggy
https://www.nitrorcx.com/25c132-14-s...ggy-green.html
The Tacon Soar is a 1/14 scale Buggy. It was designed from the ground up with pure performance in mind. Performance features derived from 1/8 scale trucks and buggies have been shrunken down in size and engineered to deliver the utmost performance in a smaller buggy package. A composite chassis serves as the base of this buggy. Mounted on the front and rear is thick composite shock towers towering over the planetary geared fluid filled differentials. Attached to the robust towers are aluminum capped, coil over adjustable, oil filled shocks providing plush and ground hugging dampening. The steering tie rods and upper and lower arms are adjustable for fine tuning of the toe and camber, effectively altering the handling characteristics of the buggy over varying terrain.
This buggy has an awesome power to weight ratio. Weighing in at slightly over 2 lbs, the vehicle is easily propelled by the 380 sized brushed motor. A brushed electronic speed controller delivers the current efficiently through an included 7.2v 1100mah Ni-Mh battery and charger. The brushed electronic speed controller is also capable of accepting 7.4v lithium batteries with a quick switch of a jumper pin. All of this power transfers through a shaft driven four wheel drive system providing ground clawing action through the performance wheels off road knobby tires. We recommend a Gens Ace 7.4v 1800mah lithium battery for an exponential increase in power and efficiency.?
The Tacon Soar ready to run package also includes a 2.4ghz radio system. With frequency hopping technology, interference is a thing of the past. No longer do you have to worry about your specific channel. The radio system will automatically take care of that for you while you are focused on handling this beast of a machine.
With a body designed with aerodynamic performance, combined with a wing on the rear end, the buggy handles exceptionally well on bumpy terrain and responds quickly with throttle and brake inputs while mid flight off of a jump. This buggy will put a huge smile on your face when you see it four wheel power sliding through a corner spitting dirt and debris out the rear end or flying over triples easily correcting itself landing on the perfect transition.
Features:
1. Tacon design treaded tires
2. Gear cover
3. Aluminum-capped, oil-filled, coil-over, 6061-T6 adjustable shocks
4. Thick composite shock towers
5. Front and rear metal gear differentials
6. LiPo Ready ESC
7. 380 Brushed Motor
8. 4WD shaft drivetrain
9. Adjustable mini Solar 655 servo with saver
10. Steel hinge-pins with rounded front bumper
11. Tacon receiver with 2.4GHz technology
12. 7.2V 1100mAh NiMH battery with 3.5mm gilded round connectors
13. 12mm wheel hexes
Specifications:
Scale: 1/14 Tacon Soar Buggy
Length: 304mm (12in)
Width: 202mm (8in)
Height: 110mm (4.3in)
Wheelbase: 186mm (7.3in)
Weight: 0.90kg (1.9lbs with battery)
Tire Type: Tacon Buggy
Chassis: Composite
Motor or Engine: 380 Brushed
Steering Servo: Solar 655
Gear ratio: 8.23
Speed Control: Brushed Lipo Ready
Radio: 2.4GHz Technology
Batteries: 7.2V NiMH with 3.5mm gilded round connector, Charger included
Shock Type: Aluminum capped, threaded, oil-filled, coil-over
Package Contents:
100% Assembled
1x 1:14 Tacon Soar Buggy
1x 2CH 2.4Hz Transmitter
1x Battery Charger (100-240V)
1x 7.2v 1100mAh Ni-MH battery
1x Instruction Manual
Required to Run:
AA Batteries for Transmitter
Features:
2. Gear cover
6. LiPo Ready ESC
Specifications:
Width: 202mm (8in)
Chassis: Composite
Gear ratio: 8.23
Package Contents:
100% Assembled
Required to Run:
