Monster Truck Radio 1/10 2.4Ghz Exceed RC Infinitive Nitro Gas Powered RTR Off Road M
https://www.nitrorcx.com/51c08-infin...red-24ghz.html
The most popular 1/10 4 wheel drive monster truck in the world just got better! At each evolutionary step, the Infinitive has been improved upon to keep it at the peak of the RC monster truck field. So how do you make an Infinitive better? Extra speed, extra adjustability, extra toughness! The new Infinitive is packed with features that have been suggested by Infinitive owners: More room for the electronics, easier access to the differentials and transmission, and more suspension adjustability. The result is the best Infinitive ever.
With the new design 2.4Ghz remote control pistol transmitter is every RC Car Driver dream to get their hands on a full-range 2.4Ghz system.
The heart of the Infinitive truck line has always been a .18 engine with reliable and consistent power for tough off-road driving. With revised porting and crankshaft, internal airflow has been optimized for increased power and torque.
RTR C factory assembled with installed engine and radio gear makes getting started easy
The 2.5mm lightweight aluminum alloy chassis provides excellent performance and durability
Front & rear skid plates for impact protection
8 long stroke oil filled shocks with firm tuned springs keep the wheels on the ground
Complete set of ball bearings for low friction and durability
High capacity fuel tank with perfect caliber makes it impossible to overflow and provides long run times
New lightweight suspension arms deliver quick suspension response and reduce the critical sprung weight and overall weight of the truck
The new .18 engine features a new crankcase and upgrades to the cylinder, piston, connecting rod and crankshaft, delivers more power, more torque and extra cooling.
- The Infinitive will be available "Ready-To-Run" making it the highest on-road performance 4-wheel drive nitro racing car available to everybody
- Completely preassembled with high quality radio gear, painted, trimmed and ready to roll
- The new .18 (18 CXP) engine provides reliable and consistent power for high performance on-road driving
- The 2.5mm lightweight aluminum alloy chassis provides excellent performance and durability
- Excellent differential system design provides quick access to the front or rear differential by removing only few screws. You can now access the front and rear differential for easy maintenance
- New lightweight suspension arms deliver quick suspension response and reduce the critical sprung weight and overall weight of the car
- Though metal disk brake system provides efficient deceleration and precise control
- High capacity fuel tank with perfect caliber makes it impossible to overflow and provides long run times
- The high quality AM transmitter and receiver work together to let you precisely control your car.
