Exceed RC Fire Red 1/10 2.4Ghz Forza .18 Engine 2-Speed RTR Ready to Run Nitro Powere
https://www.nitrorcx.com/51c812-firered-24ghz.html
The most popular 1/10 4 wheel drive 2 speed off-road buggy in the world just got better! At each evolutionary step, the Forza has been improved upon to keep it at the peak of the RC off-road buggy field. So how do you make an Forza better? Extra speed, extra adjustability, extra toughness! The new Forza is packed with features that have been suggested by Forza owners: More room for the electronics, easier access to the differentials and transmission, and more suspension adjustability. The result is the best Forza ever.With the new design 2.4Ghz remote control pistol transmitter is every RC Car Driver dream to get their hands on a full-range 2.4Ghz system.
The heart of the Forza truck line has always been a .18 engine with reliable and consistent power for tough off-road driving. With revised porting and crankshaft, internal airflow has been optimized for increased power and torque.FEATURE HIGHLIGHTS:
The Forza will be available "Ready-To-Run" making it the highest on-road performance 4-wheel drive nitro racing car available to everybody
Completely preassembled with high quality radio gear, painted, trimmed and ready to roll
The new .18 (18 CXP) engine provides reliable and consistent power for high performance on-road driving
The 2.5mm lightweight aluminum alloy chassis provides excellent performance and durability
Excellent differential system design provides quick access to the front or rear differential by removing only few screws. You can now access the front and rear differential for easy maintenance
Length:400 MM15.7 inch.
Width:250 MM9.8 inch.
Height:160 MM6.3 inch.
Wheelbase:275 MM10.8 inch.
Ground Clearance:26 MM1.02 inch.
Diameter Of Wheel:86*32 MM (F) 86*40 MM (R)
Weight:1780g
Engine:18 CXP
Weight:1780g
Engine:18 CXP
