Exceed RC 1/10 2.4Ghz Storm Blue Hyper Speed Beginner Version .16 Engine Nitro Powere
https://www.nitrorcx.com/51c818-stormblue-24ghz.html
**THE GAS CAR IS BRAND NEW** Exceed RC 1/10 Nitro Competition Racing Remote Control Car, Complete Kit with Body & Engine along with an 2-Channel Pistol Wheel Remote Control w/ 2 SERVOS !!! READY-TO-RACE OUT OF THE BOX !!! * NEW IN A BOX *
With the new design 2.4Ghz remote control pistol transmitter is every RC Car Driver dream to get their hands on a full-range 2.4Ghz system.
The Car Contains all available hop-up parts; body or engine included!!! Designed to compete in national and local competitions, manufactured at a super-modern facility, Exceed RC's nitro r/c gas cars are created with a mind for high performance racing, scale speed of 35mph+. This 4-Wheel-Driven Gas Powered Car is a 1/10th scale that combines many sophisticated performance-enhancing features that represent a culmination of the long years of Exceed RC's design experience.
Engine Beginner Version, VX 16 Engine,AM Radio, 3 kg steering servo
Engine VX 16
Engine Manufacturer Vertex
Transmission Single speed
Drive System Four Wheel Drive
Radio System Two Channel A.M.
Length 400mm
Front Track 215mm
Rear Track 205mm
Overall Height170mm
Wheelbase 270mm
Front Shock Length 85mm
Rear Shock Length 85mm
Front Tires Block Tread
Rear Tires Block Tread
Wheel Width 32mm (F) - 40mm (R)Wheel Diameter 86mm
Chassis Type 2.5mm 6061 Aluminum Alloy
Brake Type Steel Disc
Fuel Tank Capacity 75cc
Suspension Type Plastic bodied oil filled shocks
Gear Ratio1:8.038 (Single Speed)
OUR CAR HAS PART COMPATIBILITY & MODIFICATIONS WITH OTHER BRANDS LIKE HPI, TRAXX, ETC. YOU CAN CHANGE THE BODY-KIT WITH OTHER OFF ROAD BUGGY SHELLS. YOU CAN ALSO MODIFY/UPGRADE THE ENGINE. ADD NEW TIRES, NEW SUSPENSION, RE-PAINT,+ MORE!!! THIS IS A GREAT KIT FOR ANY AGE, ANYONE !!!
Product Description:
- 2-Channel Pistol Radio System Included
- Assembled Chassis
- VX16 High-Torque and Pull Start Engine with Carburetor
- Equipped with Tuned Pipe and Air Filter
- Front and rear Bevel Gear differentials
- 4 wheel Shaft-Drive System.
- Adjustable Wishbone Suspension
- No-flex chassis design for better performance.
- Alloy aluminum upper plate and chassis.
- Oil-Filled shock absorber.
- Disc-shaped brake system.
- Front universal joint shaft.
- 75 cc fuel pressure tank.
- High impact wheels.
- High traction radial tires.
- Servo saver linkage system.
- Stock engine muffler system.
Engine VX 16
Length 400mm
Front Track 215mm
Rear Track 205mm
Overall Height170mm
Wheelbase 270mm
- Assembled Chassis
