NEW Exceed RC 1/8th Alpha Blue MadWarrior 2.4 GHz Nitro Truggy w/ .21 Gas Engine RTR
https://www.nitrorcx.com/52c65-madwa...ite-24ghz.html
The new generation of 1/8 Truggy are here with newly added features and functions. Everything from the ground-up has been reinvented and modified for a totally new experience. This massive 1/8 MadWarrior Truggy comes with Level .21 engine for fast speed, polished aluminum chassis to provide clean look as well as sturdiness, adjustable shocks to have perfect landing, and a bigger fuel tank that can hold 150cc. This package comes with a 2.4 GHz radio system so you don?t have to worry about interferences.
The impressiveness of the MadWarrior Truggy can be seen right out of the box at first glance from the well-built interior to the magnificent exterior designs. From the front to the back bumper all pieces have been built to last. Included in the MadWarrior Truggy are aluminum muffler for superior protection and looks, and heavy duty metal gear steering servo for sturdiness. Even the rims are now hardened chrome rims and colossal tires so it can easily triumph over the world. Use the MadWarrior Truggy to climb off road terrain, stony hills, rocky backyards, or wherever the road may take you! MadWarrior Truggy once again set a new standard for the RC world.
The 4WD Engine-powered Truggy MadWarrior will Push your Imagination into overdrive!
Specs
Engine 21 Level
Wheelbases: 15"
Weight: 5.2kg
Features
Polished 6061 Aluminum Chassis Plates
Massive pre-glued 5" Tires Mounted on Hardened Chrome Rims with 17mm Hex Hub
1-Speed Transmission
Heavy Duty Metal Gear Steering Servo
150cc Flip-top Fuel Tank
Adjustable Threaded Aluminum Shocks
2.4 GHz radio system for wider control ranges
Specs
Engine 21 Level
Wheelbases: 15"
Weight: 5.2kg
Features
