Exceed RC MicroX 1/28 Micro Scale Buggy Ready to Run 2.4ghz Remote Control Car
https://www.nitrorcx.com/68c52-28-buggy-red--24g.html
MicroX Racing releases its smallest most compact remote control buggy to hit the market. Constructed on an molded composite chassis this buggy sports an agile 2WD drive train. A powerful brushed micro motor delivers tire spinning torque and speed to this already small and light weight chassis. Realistic buggy styling and details keep things fun and exciting. The 1/28-scale electric RTR 2WD buggy has all the features you would want in a hobby grade radio control vehicle. Proportional digital throttle control, proportional digital steering control, high current electronic speed controller and lithium battery. The vehicle is ready to run and comes with a rechargeable internal battery pack and USB charger. This buggy is fully equipped to attack your home made race course. All you need to do is take it out of the box, charge the battery and let it rip!
Features:
2WD
Molded composite chassis
Coil shocks for dampening
Realistic Buggy Body
Ready to Run
2.4ghz Radio System
Off-Road treaded tires and wheels
Shock absorbing bumpers
Powerful motor system
Specifications:
Length: 150mm
Width: 90mm
Height: 54mm
Wheelbase: 100mm
Motor RPM: 29000rpm
Gear Ratio: 1:7
Servo: Proportional
ESC and Receiver: 2 in 1
Transmitter: 2.4G
Battery: 3.7v 150mAh Ni-MH
Car Weight: 62g
Required to Run:
4 AA Batteries for Transmitter
Features:
2WD
Ready to Run
2.4ghz Radio System
Specifications:
Length: 150mm
Width: 90mm
Height: 54mm
Wheelbase: 100mm
Motor RPM: 29000rpm
Gear Ratio: 1:7
Servo: Proportional
Transmitter: 2.4G
Car Weight: 62g
Required to Run:
