MicroX Racing 1/24 Micro Scale Red Short Course Truck Ready to Run 2.4ghz RC Remote C
https://www.nitrorcx.com/68c09-24-sct-red-24g.html
MicroX Racing introduces its smallest most compact short course truck to hit the market. Constructed on an molded composite chassis this truck sports an agile 4WD shaft driven drive train. ?A powerful brushed micro motor delivers tire spinning torque and speed to this already small and light weight chassis. Realistic short course ?body and details keep things fun and exciting. The 1/24-scale electric RTR 4WD short course truck has all the features you would want in a hobby grade radio control vehicle. Proportional digital control, dedicated steering servo, high current electronic speed controller and battery. The truck is ready to run and comes with a rechargeable battery pack and charger. This truck is fully equipped to attack the short course. All you need to do is take it out of the box, charge the battery and let it rip
Features:
Shaft driven 4 wheel drive
Molded composite chassis
Coil shocks for dampening
Realistic Short Course Truck Body
Ready to Run
2.4ghz Radio System
Off-Road treaded tires and wheels
Shock absorbing bumpers
Powerful motor system
Specifications:
Length: 178mm (7in)
Width: 100mm? (4in)
Height: 65mm (2.6in)
Wheelbase: 110mm (4.3in)
Ground Clearance: 9mm (.35in)
Steering bearing: Oil bearing
Wheel: 33*12mm
Gear Ratio: 1:12.6
Servo: 1.7g
ESC and Receiver: 2 in 1
Transmitter: 2.4G
Battery: 4.8V 220mAh Ni-MH
Car Weight: 153g
Required to Run:
4 AA Batteries for Transmitter
Features:
Ready to Run
2.4ghz Radio System
Specifications:
Length: 178mm (7in)
Width: 100mm? (4in)
Wheel: 33*12mm
Gear Ratio: 1:12.6
Servo: 1.7g
Transmitter: 2.4G
Car Weight: 153g
Required to Run:
